Best drain plug washers? #832290
10/17/10 08:58 PM
10/17/10 08:58 PM
San Jose, CA
Blue69Charger Offline OP
San Jose, CA
What is the most leak free drain plug washer to use on a stock oil pan? I have a mopar reproduction hemi oil pan. I think it uses a 1/2" id washer. The plastic washer that came with it had a slow drip. I tried the rubber/steel washers from autozone and they leaked too. Copper works okay but not as good as the steel washer than I had on my old 440. I haven't been able to find a place that sells the copper washers in bulk and usually have to buy a variety pack of 3 to get the size I need.
Re: Best drain plug washers? [Re: Blue69Charger] #832291
10/17/10 09:07 PM
10/17/10 09:07 PM
Kirkland, Washington
Pacnorthcuda Offline
I posted a thread on this awhile back. General concensus was copper. Since then thats all I use, but I have had good luck with the hard fiber ones too.
Re: Best drain plug washers? [Re: Blue69Charger] #832292
10/17/10 09:10 PM
10/17/10 09:10 PM
I'd suggest another drain plug
Re: Best drain plug washers? [Re: RapidRobert] #832293
10/17/10 09:27 PM
10/17/10 09:27 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
One of the local parts stores (not a chain) sells a copper washer with an O-ring in the center. The copper allows you to tighten it so it won't fall out and determine the proper amount of crush for the O-ring. Works good on problem oil pans.
I have used aluminum washers with good luck too (aftermarket or from the Toyota dealer).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Best drain plug washers? [Re: Dads426] #832294
10/17/10 09:57 PM
10/17/10 09:57 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a new toyota gasket if you need one. Just send me your address and I`ll mail it to you. Mike
Re: Best drain plug washers? [Re: mopars4ever] #832295
10/17/10 10:33 PM
10/17/10 10:33 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I wrap the drain bolt with plumbers tape and then use a solid rubber gasket from ACE Hardware. I tighten it until the rubber gasket just barely starts to squish out from under the bolt head.
The plumbers tape should cure any leak no matter what gasket you choose to run. I like the rubber ones since they are soft and won't cause the paint to chip off.
The plastic washers eventually yellow, dry up, and split. The rubber ones also dry out after about a year or so, but they are 10 cents each so I just buy a small bag of them and throw them in the tool box.
Re: Best drain plug washers? [Re: Blue69Charger] #832296
10/17/10 10:41 PM
10/17/10 10:41 PM
AndyF Offline
AndyF  Offline
Aluminum or copper seems to work the best. The plastic ones work fine at first but then after a few heat cycles they start to leak.
Re: Best drain plug washers? [Re: AndyF] #832297
10/18/10 11:43 AM
10/18/10 11:43 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Re: Best drain plug washers? [Re: challenger70] #832298
10/19/10 01:10 AM
10/19/10 01:10 AM
San Jose, CA
San Jose, CA
Thanks guys, I've tried a Dorman rubber/steel one and it leaked for me. Maybe I overtightened it? Does anyone have a part number for the Toyota gasket? Dads426 do you have a part number for the copper/o-ring gasket?
Re: Best drain plug washers? [Re: Blue69Charger] #832299
10/19/10 09:18 AM
10/19/10 09:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Actually if it fits Saturn made one of the best seals made.we used them a lot on cars at work that had the same size drain.When we were getting them they were like 2 bucks each for the plug and gasket.Its a 2 part setup.Metal and a silicone type seal.Rocky
Chrysler Firepower
Re: Best drain plug washers? [Re: therocks] #832300
10/19/10 10:06 AM
10/19/10 10:06 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Mopars current replacement drain plug is a rubber coated steel plug that works very well
