Re: Best drain plug washers?
[Re: RapidRobert]
#832293
10/17/10 09:27 PM
10/17/10 09:27 PM
Posts: 1,443 Maryland
Dads426
Maryland
One of the local parts stores (not a chain) sells a copper washer with an O-ring in the center. The copper allows you to tighten it so it won't fall out and determine the proper amount of crush for the O-ring. Works good on problem oil pans.
I have used aluminum washers with good luck too (aftermarket or from the Toyota dealer).
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Blue69Charger]
#832299
10/19/10 09:18 AM
10/19/10 09:18 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Actually if it fits Saturn made one of the best seals made.we used them a lot on cars at work that had the same size drain.When we were getting them they were like 2 bucks each for the plug and gasket.Its a 2 part setup.Metal and a silicone type seal.Rocky
Chrysler Firepower
