Re: 440 "six pak" vs 440 "830 cfm annular" in bracket trim
[Re: 67383scuda]
#831963
10/17/10 04:43 PM
10/17/10 04:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The 830 is small so in that case I would say the 6 pac but I hate running multiple carbs... I would go with a 1050 dom... JMO
[Re: 67383scuda]
#831965
10/18/10 01:31 AM
10/18/10 01:31 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Mr P. Body is right about the 830 on your combo. The six pack flows about 950-970cfm at best (measured as a large cap 4bbl), which is great but not optimal for you combo. The 1050cfm carb would put you there. The 830 would not be bad, but you may not pull the numbers you want with that carb.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: 67383scuda]
#831968
10/18/10 02:49 PM
10/18/10 02:49 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I have dyno tested several stock type six pak set ups and a bunch of different single four barrel intakes and carbs, 600 to 1050 CFM Dominator. All of the Mopar V8 I have tested and raced have made more power and torque with more CFM than smaller CFM My low deck street stroker motor had a six pak set up on it until I swapped the heads to a set of Indy 440-1 with a Indy 400-3 intake. That six pak set up works great at the track and on the street As far as the CFM on the stock six pak carbs. the factory rates them at 350 CFM on the 440 center carbs. and 500 CFM on the outboard for a total of 1350 CFM
[Re: sshemi]
#831970
10/18/10 03:47 PM
10/18/10 03:47 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Yep, 350 and 500 are the way Holley rated them using the irrelevant 2 barrel formula. As I said earlier D.C. listed them as 295 and 425 which lines up perfect with the venturi and throttle bore diameters of similar 4 barrel carbs.
[Re: 67383scuda]
#831972
10/18/10 04:00 PM
10/18/10 04:00 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Six packs are cool and work great, but I wouldn't want one on something I was going to be racing every weekend. Much easier to work on a single 4.
[Re: sixpackgut]
#831974
10/18/10 04:09 PM
10/18/10 04:09 PM
an8sec70cuda
i have it down to a science and i have actually caught myself bitchin bout trying to change jets on the secondarys on a 4bbl
an fuel lines on a sixpack makes life much simpler
Ray, you're the exception, lol. No doubt they work good when setup correctly. Your car flies and your advice was priceless when I was dialing in Dad's six pack.
