hi moparts!
the car
-- 3100 lb a body with 440
11 to 1
auto
600 + cam lift solid
runs high tens 1/4 now, but planning a aluminum head swap (victors or at least the rpm edelbrocks)
which carburetor system would be the "best" overall. factoring in things like
1. all out performance
2. reliability
3. any constant "tuning" issues other than adjusting for air quality whatever
basically the worked over 830 annular discharge on the rpm intake works great with the "average at best 906 head" , its consistent and never does anything "wrong"--yay!
ive always wanted a 3 x 2's cause its neat and i hear the cfm is like 1100 WOT.
assuming things like manifold flow numbers are similar (six pak vs victor single 4) which induction system would make the better bracket setup on a high 9's low 10's 1/4 miler?
thanks!
