Manual choke kit for 6 pack center? #831886
10/17/10 02:16 PM
10/17/10 02:16 PM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline OP
Been driving around for years with the regular bimetal choke coil working half the time. When it gets cold I end up wiring it open.
So I got ahold of a holley 45-225 manual choke kit incorrectly thinking I could use that on a 2300 series like it says it should.
So has anybody ever rigged up manual choke cable on a 6 pack?
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Manual choke kit for 6 pack center? [Re: BrianShaughnessy] #831887
10/17/10 06:49 PM
10/17/10 06:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have a manual cable that I ran into the glove box. Can't even see it. Works great
Re: Manual choke kit for 6 pack center? [Re: Mr.Yuck] #831888
10/17/10 08:23 PM
10/17/10 08:23 PM
Thanks, I was hoping to see how things were rigged up at the carb. The cable inside isn't really my hangup.
The 45-225 is made for carbs with the round adjustable choke setup, not the old bimetal in the manifold deal like on 6 pack carbs.
Re: Manual choke kit for 6 pack center? [Re: BrianShaughnessy] #831889
10/17/10 08:32 PM
10/17/10 08:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
sorry motor is apart or I'd show you.
Re: Manual choke kit for 6 pack center? [Re: Mr.Yuck] #831890
04/16/14 01:00 AM
04/16/14 01:00 AM
Virginia, USA
rocket34 Offline
rocket34  Offline
Virginia, USA
I know this is old but anyone have any tips/specialized parts they have used to set up a manual choke on a six pack?
69 Road Runner work in progress
Re: Manual choke kit for 6 pack center? [Re: rocket34] #831891
04/16/14 09:22 AM
04/16/14 09:22 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
FWIW in this months Hot Rod (June) there is an article where they fix some problems with a six-pack engine. In that article they modify the choke assembly to accept a remote electric choke coil used on 75-79 360's and 400's with the Holley two-barrel. This would be a good idea for someone to make a kit to do this.
Re: Manual choke kit for 6 pack center? [Re: 63stabamatic] #831892
04/16/14 10:42 AM
04/16/14 10:42 AM
Virginia, USA
rocket34 Offline
rocket34  Offline
Virginia, USA
Thanks! I will grab that issue.
Re: Manual choke kit for 6 pack center? [Re: 63stabamatic] #831893
04/16/14 10:46 AM
04/16/14 10:46 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If you look closely at the article it appears the intake was substantially modified {as in choke well ground down the side}...This might scare off most as there's no return from that..
Re: Manual choke kit for 6 pack center? [Re: Mr.Yuck] #831894
07/19/14 07:11 PM
07/19/14 07:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Hello Mr yuck! did you every get your motor together? Just kidding as I know this is a old thread.
I was doing some searching on manual choke cable installation on a 6 pack and wondering if you still run that. Or if you could take a picture. '
Or any help from anyone else, as I run edlebrock heads with no heat risers and have my choke wired open. It runs so much better with a choke when cold. Once hot it's great. Thinking a cable is the way to go?
Re: Manual choke kit for 6 pack center? [Re: Challenger 1] #831895
07/19/14 07:45 PM
07/19/14 07:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
Is the center carb a 2300 series carb? I found this, I betting it's the way to go if I want a cable? web page
Re: Manual choke kit for 6 pack center? [Re: Challenger 1] #831896
07/19/14 10:08 PM
07/19/14 10:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
I have 2 other old holly carbs both with manual choke. So figured I could take one choke off and use it on my center 6 pak carb? But it don't look like it'll work like said above.
Anybody been "down this road"?
Re: Manual choke kit for 6 pack center? [Re: Challenger 1] #831897
07/19/14 10:18 PM
07/19/14 10:18 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
https://board.moparts.org/ubbthreads/show...amp;Search=true
This posting might be of interest to you.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Manual choke kit for 6 pack center? [Re: hemi71x] #831898
07/19/14 10:54 PM
07/19/14 10:54 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thank you, yes it was. Cable not possible on 6 pak. Electric choke sounds like the way to go. Thanks again.
Re: Manual choke kit for 6 pack center? [Re: hemi71x] #831899
07/20/14 01:34 AM
07/20/14 01:34 AM
Shoreline, Washington
72roadrunnergtx Offline
Still working perfectly I might add.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
