Manual choke kit for 6 pack center?
#831886
10/17/10 02:16 PM
10/17/10 02:16 PM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
Been driving around for years with the regular bimetal choke coil working half the time. When it gets cold I end up wiring it open.
So I got ahold of a holley 45-225 manual choke kit incorrectly thinking I could use that on a 2300 series like it says it should.
So has anybody ever rigged up manual choke cable on a 6 pack?
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Manual choke kit for 6 pack center?
[Re: Mr.Yuck]
#831888
10/17/10 08:23 PM
10/17/10 08:23 PM
BrianShaughnessy
I have a manual cable that I ran into the glove box. Can't even see it. Works great
Thanks, I was hoping to see how things were rigged up at the carb. The cable inside isn't really my hangup.
The 45-225 is made for carbs with the round adjustable choke setup, not the old bimetal in the manifold deal like on 6 pack carbs.
[Re: Mr.Yuck]
#831890
04/16/14 01:00 AM
04/16/14 01:00 AM
Posts: 115 Virginia, USA
rocket34
Virginia, USA
I know this is old but anyone have any tips/specialized parts they have used to set up a manual choke on a six pack?
69 Road Runner work in progress
[Re: Mr.Yuck]
#831894
07/19/14 07:11 PM
07/19/14 07:11 PM
Challenger 1
Cincinnati, Ohio
sorry motor is apart or I'd show you.
Hello Mr yuck! did you every get your motor together? Just kidding as I know this is a old thread. I was doing some searching on manual choke cable installation on a 6 pack and wondering if you still run that. Or if you could take a picture. '
Or any help from anyone else, as I run edlebrock heads with no heat risers and have my choke wired open. It runs so much better with a choke when cold. Once hot it's great. Thinking a cable is the way to go?
