Purpose of the Window on a distributor #83181
07/02/08 05:51 PM
07/02/08 05:51 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Just a random question as I sat there looking at my Distributor tonight.....Whats the purpose for this so called "GM Window"
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Purpose of the Window on a distributor [Re: Pyper70] #83182
07/02/08 06:21 PM
07/02/08 06:21 PM
Back when distributors had breaker points, that window is where you adjusted them on a GM--with an allen wrench.
IN FACT, before I finally "went" electronic back then, I once shorted a GM dist for my 340. Unfortunately, the , uh, 'machinist' who did the work on the tang got it so far off center, I'd a' been as accurate myself, using a file and a hacksaw. Still got the thing, somewhere
Re: Purpose of the Window on a distributor #83183
07/02/08 07:49 PM
07/02/08 07:49 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Interesting.....thanks for the enlightenment....
Re: Purpose of the Window on a distributor [Re: Pyper70] #83184
07/02/08 07:53 PM
07/02/08 07:53 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
It was a great system. Just slap your dwell meter on and set the points with the engine running without all the trial and error/feeler gauge crap on the other makes.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Purpose of the Window on a distributor [Re: gamagoat6x6] #83185
07/02/08 08:57 PM
07/02/08 08:57 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
28 degrees if I remember my old Belair setting correctly. Set dwell with the key, set idle and timing and you were away.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: Purpose of the Window on a distributor [Re: 78D150CLUB] #83186
07/03/08 06:38 PM
07/03/08 06:38 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
Actually it was 28 - 32
Re: Purpose of the Window on a distributor [Re: mopardad] #83187
07/03/08 07:20 PM
07/03/08 07:20 PM
Ontario, Canada
78D150CLUB Offline
78D150CLUB  Offline
Ontario, Canada
That was the range, but the old 283 liked 28 right on, always ran best that way.
Dunno why.
Re: Purpose of the Window on a distributor [Re: 78D150CLUB] #83188
07/04/08 07:34 AM
07/04/08 07:34 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I still have ay least 3 of the flexible adjusters for them.I used them almost every day at work before.One I have is almost brand new.Best thing about them is you can pull the allen and turn it around and you have a nice flat screwdriver to agjust carbs.Rocky
Chrysler Firepower
