Purpose of the Window on a distributor
#83181
07/02/08 05:51 PM
07/02/08 05:51 PM
Posts: 5,904 Athens, Greece
Pyper70
Athens, Greece
Just a random question as I sat there looking at my Distributor tonight.....Whats the purpose for this so called "GM Window"
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Purpose of the Window on a distributor
[Re: Pyper70]
#83182
07/02/08 06:21 PM
07/02/08 06:21 PM
Back when distributors had breaker points, that window is where you adjusted them on a GM--with an allen wrench.
IN FACT, before I finally "went" electronic back then, I once shorted a GM dist for my 340. Unfortunately, the , uh, 'machinist' who did the work on the tang got it so far off center, I'd a' been as accurate myself, using a file and a hacksaw. Still got the thing, somewhere
#83183
07/02/08 07:49 PM
07/02/08 07:49 PM
Pyper70
Athens, Greece
Interesting.....thanks for the enlightenment....
[Re: gamagoat6x6]
#83185
07/02/08 08:57 PM
07/02/08 08:57 PM
Posts: 1,475 Ontario, Canada
78D150CLUB
My avatar is a self portrait!!
Ontario, Canada
28 degrees if I remember my old Belair setting correctly. Set dwell with the key, set idle and timing and you were away.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
[Re: 78D150CLUB]
#83186
07/03/08 06:38 PM
07/03/08 06:38 PM
Posts: 1,510 Manheim PA.
mopardad
Manheim PA.
Actually it was 28 - 32
[Re: mopardad]
#83187
07/03/08 07:20 PM
07/03/08 07:20 PM
78D150CLUB
Ontario, Canada
That was the range, but the old 283 liked 28 right on, always ran best that way. Dunno why.
[Re: 78D150CLUB]
#83188
07/04/08 07:34 AM
07/04/08 07:34 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
I still have ay least 3 of the flexible adjusters for them.I used them almost every day at work before.One I have is almost brand new.Best thing about them is you can pull the allen and turn it around and you have a nice flat screwdriver to agjust carbs.Rocky
Chrysler Firepower
