Hot Rod Flatz, or similar paint practicality
#831310
10/16/10 07:39 PM
10/16/10 07:39 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Looking to paint my truck Semi gloss Green or some other color. Wondering how hard is it to clean after running through the mud boggs? Anyone? Curt
Oh yeah...THAT'S gonna leave a mark!
Re: Hot Rod Flatz, or similar paint practicality
[Re: Curt]
#831311
10/16/10 10:39 PM
10/16/10 10:39 PM
Posts: 93 Anacortes, WA
russ71satellite
Anacortes, WA
This type of paint will be more difficult to clean, as you have guessed. Dirt and dust are simply harder to remove.
71 Satellite Sebring, all stock 1989 Dodge Daytona, daily driver 2008 PT Cruiser
[Re: Curt]
#831314
10/18/10 09:43 AM
10/18/10 09:43 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
There are few ways to get that semi-gloss look , so you need to figure out which way you want to go .One of the ways is using base/clear system with flattening agent added in the clearcoat, you can adjust the sheen with flattening agent.You can also buy matte clear already premixed, just add hardener. Most paint brands have their version. Another way is single stage system with flattening agent. You can also add clearcoat hardener into basecoat and have it will have that semi-gloss look.
Any one of them will be easy to wash the dirt off, the problem you will run into if you go for more matte,flat or egg-shell sheen, the more you rub on it, the more shinier it will get and will create noticeable spots, that's what you need to worry about, but if you go for semi-gloss, you'll have alot less of these problems
[Re: elitecustombody]
#831315
10/18/10 07:11 PM
10/18/10 07:11 PM
Curt
JAX FLA
Ok, thanks... I guess experimentation is in order. Curt
