Z bar Bracket location for B-Body
#829928
10/14/10 08:52 PM
10/14/10 08:52 PM
Posts: 15 Savannah, GA
SavannahMoparMan
Savannah, GA
I am converting a 67 Coronet 440 from Automatic to a 4 speed. I have all the parts to do it, but I need to know if there is any specific demensional data available for the placement of the z bar mounting "frame bracket " that I am going to weld in. I would prefer to measure it...rather than put the motor and trans in to position it. Can anyone help? Thanks!
Savannah Mopar Man
67 Coronet 440 Street Cruiser
67 Coronet 440 Big Block/4 speed,Tubbed/Narrowed
67 Coronet 440 Convertible Project
72 Satellite 340/727 Street Cruiser
71 Demon 360/727/4200 stall/4:56 posi
73 Gold Duster 318/Auto/AC/Ps/PDB
72 Adventurer Sport 318 Auto AC PS PB LngBed
Re: Z bar Bracket location for B-Body
[Re: SavannahMoparMan]
#829929
10/14/10 09:32 PM
10/14/10 09:32 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
There should be a small slot in the frame where the bracket has a corresponding tang that fits in it. They say 71 and later are different but I personally compared them and they are the same bracket in the same location. The bracket doesn't sit flush on the frame so that dirt and dust can slid under it. Look and see if there is a access hole in the drivers inner fender well and if you look on the top of the frame just inside the hole you should find it there.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: AlexP]
#829931
10/15/10 03:38 PM
10/15/10 03:38 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Here is a pic of the location. Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#829932
10/15/10 03:39 PM
10/15/10 03:39 PM
Posts: 4,285 Ohio
64dodge572
Ohio
[Re: kilroy]
#829933
10/15/10 05:40 PM
10/15/10 05:40 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I don't think that the 67 has that slot, that was something that came about later.
[Re: 64dodge572]
#829935
10/19/10 08:49 PM
10/19/10 08:49 PM
SavannahMoparMan
Savannah, GA
THANKS FOR THE INFORMATION ON THE Z-BAR...THAT HELPED ALOT. I CERTAINLY APPRECIATE IT!!!
Savannah Mopar Man
