Z bar Bracket location for B-Body #829928
10/14/10 08:52 PM
10/14/10 08:52 PM
Savannah, GA
SavannahMoparMan Offline OP
Savannah, GA
I am converting a 67 Coronet 440 from Automatic to a 4 speed. I have all the parts to do it, but I need to know if there is any specific demensional data available for the placement of the z bar mounting "frame bracket " that I am going to weld in. I would prefer to measure it...rather than put the motor and trans in to position it. Can anyone help?
Thanks!
Savannah Mopar Man 67 Coronet 440 Street Cruiser 67 Coronet 440 Big Block/4 speed,Tubbed/Narrowed 67 Coronet 440 Convertible Project 72 Satellite 340/727 Street Cruiser 71 Demon 360/727/4200 stall/4:56 posi 73 Gold Duster 318/Auto/AC/Ps/PDB 72 Adventurer Sport 318 Auto AC PS PB LngBed
Re: Z bar Bracket location for B-Body [Re: SavannahMoparMan] #829929
10/14/10 09:32 PM
10/14/10 09:32 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
There should be a small slot in the frame where the bracket has a corresponding tang that fits in it. They say 71 and later are different but I personally compared them and they are the same bracket in the same location. The bracket doesn't sit flush on the frame so that dirt and dust can slid under it. Look and see if there is a access hole in the drivers inner fender well and if you look on the top of the frame just inside the hole you should find it there.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Z bar Bracket location for B-Body [Re: SavannahMoparMan] #829930
10/14/10 09:34 PM
10/14/10 09:34 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Brewers enclosed one with my kit. I'm sure they would be happy to fax you one.
It made it so much easier. My friends was crooked and he spent a pretty penny before he realized it.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Z bar Bracket location for B-Body [Re: AlexP] #829931
10/15/10 03:38 PM
10/15/10 03:38 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Here is a pic of the location.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Z bar Bracket location for B-Body [Re: 64dodge572] #829932
10/15/10 03:39 PM
10/15/10 03:39 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
#2
FAX 937-947-4419
Re: Z bar Bracket location for B-Body [Re: kilroy] #829933
10/15/10 05:40 PM
10/15/10 05:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think that the 67 has that slot, that was something that came about later.
Re: Z bar Bracket location for B-Body [Re: JohnRR] #829934
10/15/10 07:51 PM
10/15/10 07:51 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I think the slot started late in 70.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Z bar Bracket location for B-Body [Re: 64dodge572] #829935
10/19/10 08:49 PM
10/19/10 08:49 PM
Savannah, GA
Savannah, GA
THANKS FOR THE INFORMATION ON THE Z-BAR...THAT HELPED ALOT. I CERTAINLY APPRECIATE IT!!!
