where to get new fuel gauge?
#82985
07/02/08 08:30 AM
07/02/08 08:30 AM
Posts: 60 Smith Mtn Lake, VA
karls67gtx
Smith Mtn Lake, VA
does anyone make new fuel gauges? i am pretty sure that mine is bad in the dash, i have done a few tests and the gauge does not move even after i ground out the sending wire. will this have to be fixed or replaced with a new one? any ideas, has anyone taken there dash apart and fixed it somehow? thanks again, karl
Mopar Man
Re: where to get new fuel gauge?
[Re: karls67gtx]
#82987
07/02/08 09:20 AM
07/02/08 09:20 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
No movement after grounding the sending wire does not necessarily mean the gauge is bad. You will have to remove the dash to test it though. If you have a battery charger, you can put it on the 6 volt setting or the lowest amperage 12 volt setting, put the ground to the instrument housing and briefly touch the positive to the appropriate lug sticking up from the pin circle on the circuit board. If the pins are secure, the gauge should rise to full. Dont let it peg and hold there!
Some common problems include loose pins (solder them in place to resecure them), corrosion at the little attaching nuts, or a bad voltage regulator(there are solid state ones available for purchase, or make your own-check the tech bulletins here)
There is an very good article on this subject in this month's(August) Mopar Muscle magazine. They do a step-by-step How-to on an inexpensive yet effective, 1967 Barracuda dash restoration.
I sent my gauges to Realtime Engineering and had them test calibrate and install their voltage regulator. Turn-around was quick, prices are very reasonable, and they updated my clock to quartz movement too. I have a 1968 Barracuda, and the voltage regulator is internal inside the gas gauge. It required a little more work to upgrade the voltage regulator. Great guys there!!! Highly recomended!!!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#82988
07/02/08 04:48 PM
07/02/08 04:48 PM
Posts: 556 Arkansas
GregGarner
Arkansas
Thanks for the kind words JBC426! To add to this discussion, you can also use a 9V battery across the gauge to find out if it is OK or not. As before, don't leave it on there very long, just long enough to see if the gauge moves. If your fuel gauge is bad, we can usually rebuild it for $60. Greg Garner www.rt-eng.com1-479-756-2757
