71 440 flywheel/clutch starter combos.... #829513
10/14/10 11:15 AM
10/14/10 11:15 AM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
Hey Guys
what size fly wheel and clutch/press.plate and bellhousing is reccomended for an auto to 4-speed swap on a 71 440 (internal balance) going into an e-body... Any starter issues to consider ??
Also is anyone still selling the pilot bushing for the auto crank to manual trans conversion... napa seems to have discontinued them...
We're more concerned with function on the street over originality...
shawn
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: 71 440 flywheel/clutch starter combos.... [Re: smac77] #829514
10/14/10 11:46 AM
10/14/10 11:46 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
They came with a 513 bellhousing and a 10 1/2 clutch...That's what I would go with..
CHECK OUT MY NEW WEB SITE !
Re: 71 440 flywheel/clutch starter combos.... [Re: anlauto] #829515
10/14/10 01:46 PM
10/14/10 01:46 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
I guess that would also need a 130t flywheel ?
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: 71 440 flywheel/clutch starter combos.... [Re: anlauto] #829516
10/14/10 01:55 PM
10/14/10 01:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Year One used to have the undersized pilot bushings.
You probably want to use the 10 1/2 flywheel and clutch
Starter I'd use the smaller direct drive starter over the stock reduction gear
Re: 71 440 flywheel/clutch starter combos.... [Re: anlauto] #829517
10/14/10 03:01 PM
10/14/10 03:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In '71 all big blocks (including the Hemi) used a 10.95" clutch. The pressure plate is scalloped to use the 10.5" bolt pattern.
Re: 71 440 flywheel/clutch starter combos.... [Re: John_Kunkel] #829518
11/11/10 04:00 PM
11/11/10 04:00 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
what about the flywheel ?? Is there a difference in application between a 143 tooth and a 130 tooth... everything I read seems to conflict..
this is an internal balanced 440 engine...
I have a 513 bellhousing and now a 10 1/2 clutch... so which flywheel is best? Yes i know I'm working backwards here
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: 71 440 flywheel/clutch starter combos.... [Re: smac77] #829519
11/11/10 04:04 PM
11/11/10 04:04 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
The 143T flywheel won't work in the 513 bellhousing. You need the 130T wheel.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 71 440 flywheel/clutch starter combos.... [Re: 70440+6bbl] #829520
11/11/10 04:22 PM
11/11/10 04:22 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The 143 tooth is an 11" unit.
The 130 is a 10.5".
The scalloped pp(10.95") uses a 130 tooth flywheel with a 10.5 pattern.
If you have a nuetral balance engine, you need a nuetral balance flywheel. Just put the bushing designed to go in the torque converter register of the crank.
http://www.brewersperformance.com/proddetail.asp?prod=PB876&cat=16
I wouldn't recommend the needle bearing here.
You are probably going to have to cut the first 3/4" or so off the pilot end of the input shaft of the trans. Bevel the edge. Measure first, there is a good chance there is already a M/T crank in there right now. Then you only need to put a atandard pilot bushing in there and you are done.
MB
Re: 71 440 flywheel/clutch starter combos.... [Re: HPMike] #829521
11/11/10 07:34 PM
11/11/10 07:34 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I would use a reconditioned OEM flywheel from Brewers or Passon INSTEAD of a new not made in USA flywheel. I had a fitment problem with a flywheel from Mcleod. The ring gear was too close to the block and the teeth on the ring gear were not as deep as OEM causing a starter binding issue. Brewers has a nice reproduction of the alum belhousing to use with this swap. The starter is the same from auto to manual BTW.
Re: 71 440 flywheel/clutch starter combos.... [Re: THESHAKERPROJECT] #829522
11/12/10 11:12 AM
11/12/10 11:12 AM
Berks County, PA
V0B Cuda Offline
V0B Cuda  Offline
Berks County, PA
I have a 1970 440+6 Cuda, that I had converted to the 11" cast iron bell housing and clutch setup in the early 80's. I have since restored it back to original and I used Brewers for parts. I bought a reconditioned original 10.5" 6 pack flywheel from them and it was perfect. I used the same starter and it works fine. The people at Brewers will help you with any questions.
Vitamin C-1970 Cuda 440-6 {since 1978}
Re: 71 440 flywheel/clutch starter combos.... [Re: V0B Cuda] #829523
11/15/10 10:58 PM
11/15/10 10:58 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
Awesome, thanks guys... I'll give brewers a shout...
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
Re: 71 440 flywheel/clutch starter combos.... [Re: THESHAKERPROJECT] #829524
11/22/10 08:13 PM
11/22/10 08:13 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
After asking zillion questions about aftermarket flywheels, this was the route I went.
I used the Brewer's 130T recon and I'm thrilled with it.
