727 trans help #829254
10/13/10 10:54 PM
10/13/10 10:54 PM
TN
SCATPACK 1 Offline OP
TN
can anyone measure the O.D. of the pump drive hub on your 727 converter. this is the hub that the pump seal fits over.
Old Geezer Racing
Re: 727 trans help [Re: SCATPACK 1] #829255
10/13/10 11:29 PM
10/13/10 11:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
1.872"
Re: 727 trans help [Re: WILD BILL] #829256
10/13/10 11:58 PM
10/13/10 11:58 PM
TN
TN
thanks wild bill. mine is 1.874. My trans is leaking again. Im trying to figure it out. going crazy. I have had everything checked. Im beginning to think my case is bad. I just checked the converter. Its a 8" tci rebuilt by ptc. No cracks in the welds anywhere. the flex plat has only .003 runout and front to back runout .008. the case had some scratches in the bottom of the front sealing ring surface. We sanded the scratches out. I took the trans to a very good trans expert. he thought the pump ring did not fit good enough. It stayer dry for about one trip down the driveway.
Old Geezer Racing
Re: 727 trans help [Re: SCATPACK 1] #829257
10/14/10 07:05 AM
10/14/10 07:05 AM
virginia
572stealth Offline
572stealth  Offline
virginia
I had the same problem, turned out the converter was cracked at the base of the hub that goes into the crank. welded it up no problems since. I found the crack by pressure testing the converter at my machine shop.
Re: 727 trans help [Re: SCATPACK 1] #829258
10/14/10 09:55 AM
10/14/10 09:55 AM
NC
440Jim Offline
440Jim  Offline
NC
I can't find the source, but I believe the spec range is 1.872” to 1.875” dia.
But I would look to something else for the cause rather than the diameter.
Re: 727 trans help [Re: 440Jim] #829259
10/14/10 10:16 AM
10/14/10 10:16 AM
Hemiroid Offline
Hemiroid  Offline
This is not a bash, but wasn't it PTC that had some converters leaking through welds a while back?
Re: 727 trans help [Re: Hemiroid] #829260
10/14/10 11:32 AM
10/14/10 11:32 AM
TN
TN
I checked with ptc they said they would check it and repair if needed.
Old Geezer Racing
Re: 727 trans help [Re: Hemiroid] #829261
10/14/10 11:34 AM
10/14/10 11:34 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I would bet the converter is the cause. Friend of mine has 2 race cars. Both with 727's i built him And both started leaking out the bellhousing. He has 8" ptc converters in them. Both had cracks around the hub that goes into the crank. He just carried one back to Kenny yesterday for him to weld up.
Re: 727 trans help [Re: 572stealth] #829262
10/14/10 12:23 PM
10/14/10 12:23 PM
TN
TN
I've got it out and will have it checked. thanks for the input.
Old Geezer Racing
