727 trans help
#829254
10/13/10 10:54 PM
10/13/10 10:54 PM
Posts: 1,505 TN
SCATPACK 1
TN
can anyone measure the O.D. of the pump drive hub on your 727 converter. this is the hub that the pump seal fits over.
Old Geezer Racing
Re: 727 trans help
[Re: WILD BILL]
#829256
10/13/10 11:58 PM
10/13/10 11:58 PM
Posts: 1,505 TN
SCATPACK 1
TN
thanks wild bill. mine is 1.874. My trans is leaking again. Im trying to figure it out. going crazy. I have had everything checked. Im beginning to think my case is bad. I just checked the converter. Its a 8" tci rebuilt by ptc. No cracks in the welds anywhere. the flex plat has only .003 runout and front to back runout .008. the case had some scratches in the bottom of the front sealing ring surface. We sanded the scratches out. I took the trans to a very good trans expert. he thought the pump ring did not fit good enough. It stayer dry for about one trip down the driveway.
Old Geezer Racing
Re: 727 trans help
[Re: Hemiroid]
#829260
10/14/10 11:32 AM
10/14/10 11:32 AM
Posts: 1,505 TN
SCATPACK 1
TN
I checked with ptc they said they would check it and repair if needed.
Old Geezer Racing
Re: 727 trans help
[Re: 572stealth]
#829262
10/14/10 12:23 PM
10/14/10 12:23 PM
Posts: 1,505 TN
SCATPACK 1
TN
I've got it out and will have it checked. thanks for the input.
Old Geezer Racing
