68 Barracuda formula s 4 speed trans, please help ID #829171
10/13/10 09:09 PM
10/13/10 09:09 PM
Northern Virginia
barracuda7 Offline OP
Northern Virginia
I just bought the 68 383 Barracuda, factory 4speed. The trans still there.
However I couldnt find the VIN stamp on the trans right side. There are only casting number 95639 on the right side and C- 95658 G in tailshaft.
According to "67-74 Barracuda&Challenger Restoration- Paul Herd" , begin 1968 a 4speed 833 has a new style and has VIN stamp on right side pad.
My car build 02/23, is it possible it had earlier 833 4speed? Or probably the A833 reaplced?
Anyone here know 68 383 4speed build before 02/23 and have VIN stamp on right side pad?
Thanks in advance
Re: 68 Barracuda formula s 4 speed trans, please help ID [Re: barracuda7] #829172
10/13/10 11:43 PM
10/13/10 11:43 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
IIRC the stampings on the 68's were on the bell-housing top right and the same area for the engine. Side pads were '69 and on.
Re: 68 Barracuda formula s 4 speed trans, please help ID [Re: barracuda7] #829173
10/14/10 12:56 AM
10/14/10 12:56 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Is the pad there? I had a 68 18-spline case that was stamped with the VIN from the Charger it came out of, but the case is long gone now.
Re: 68 Barracuda formula s 4 speed trans, please help ID [Re: Jim_Lusk] #829174
10/14/10 11:46 PM
10/14/10 11:46 PM
Northern Virginia
Northern Virginia
Jim, there are no pad, just casting number.
BTW, I saw you in other thread about Bigblock Kmember, could you please help me ID this Kmember?
Pic:
http://img808.imageshack.us/i/5927467mvc031s.jpg/
Im pretty sure it for 68 383 Bigblock Dart/Barracuda without power steering but it not look like the one in Schumacher side
Re: 68 Barracuda formula s 4 speed trans, please help ID [Re: barracuda7] #829175
10/15/10 12:15 AM
10/15/10 12:15 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I think somebody said that was a slant k-member. It's not a small block or big block, that's for sure.
