Found the leak, how do I fix it? (tranny) (Updated) #82870
07/01/08 08:25 PM
07/01/08 08:25 PM
BDW Offline OP
BDW  Offline OP
I think I found the source of my 727 leak. Is this something I can do myself, and how?
Pic is looking from rear of car.
Re: Found the leak, how do I fix it? (tranny) [Re: BDW] #82871
07/01/08 09:02 PM
07/01/08 09:02 PM
Brodheadsville,PA
Frank_O_Jr Offline
super street
Frank_O_Jr  Offline
super street
Brodheadsville,PA
I have stopped this leak on a trans by pushing in the shaft and slobbering silicone sealer (orange) all over the end of it.Clean with gumout.The only other way is to remove trans pan,trans tail housing.Slide out shaft and replace O ring.
Re: Found the leak, how do I fix it? (tranny) [Re: Frank_O_Jr] #82872
07/01/08 09:54 PM
07/01/08 09:54 PM
BDW Offline OP
BDW  Offline OP
Tell me more about pushing the pin in? How much and how hard can I push on it?
I definitely don't like the idea of removing the tailshaft. Is this something you can even do with the tranny in the car?
Thx
Re: Found the leak, how do I fix it? (tranny) [Re: BDW] #82873
07/02/08 01:23 AM
07/02/08 01:23 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
You won,t hurt it by pushing on it. It may not move. Just get it super clean with the spray cleaner tube around the pin/hole gap real good and dry it fast, then seal with rtv quickly before the trans fluid runs back. Pack it in with your finger. RTV won,t stick if its not clean/dry.
Re: Found the leak, how do I fix it? (tranny) [Re: earlybee] #82874
07/02/08 06:10 AM
07/02/08 06:10 AM
BDW Offline OP
BDW  Offline OP
I'll give it a shot. I'll drain some fluid from the pan to get the level below this point. So it will remain dry after clean-up.
Any other advice on the o-ring replacement if the silicon doesn't work?
Thx
Re: Found the leak, how do I fix it? (tranny) [Re: BDW] #82875
07/02/08 09:05 AM
07/02/08 09:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
just jack the back of the car up so the fluid runs forward in the trans , clean it good with brake cleaner and get permatex ultra blue or ultra copper and let if cure , 24 hrs , before putting the rear back on the ground .
Re: Found the leak, how do I fix it? (tranny) [Re: JohnRR] #82876
07/02/08 10:44 AM
07/02/08 10:44 AM
I did this a couple years ago to my sons car worked great, just make sure to get it clean and dry.
Re: Found the leak, how do I fix it? (tranny) [Re: BDW] #82877
07/02/08 11:48 AM
07/02/08 11:48 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Thx
I did the same fix with JB Weld! Same advice, raise the rear to keep fluid away from that area. Clean real well with brake cleaner/carb cleaner/laquer thinner (some strong solvent) and blow dry real well. I was worried that the shaft needed to rotate to some degree but it doesn't. The fix worked for years.
Re: Found the leak, how do I fix it? (tranny) UPDATED [Re: Pacnorthcuda] #82878
07/08/08 06:30 PM
07/08/08 06:30 PM
BDW Offline OP
BDW  Offline OP
I'm almost hesitant to say it, but it's been a week and I haven't seen a drip yet.
I took the silicone advice. Cleaned it real good with brake cleaner, wiped it down, then put on a dab of Permatex Ultra Black.
This will be a miracle if it holds, I thought I had fixed in the past. Granted this is a different spot.
I'll keep my fingers crossed.
Thanks for the help.
