Mopar Performance die cast valve covers #82632
07/01/08 11:48 AM
07/01/08 11:48 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Hows the best way to knock out the knock outs with out making them look bad?
Re: Mopar Performance die cast valve covers [Re: Robbins] #82633
07/01/08 12:26 PM
07/01/08 12:26 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Step drill, hole saw, die grinder w/a carbide bit...though alot of people have successfully blasted away at them with a hammer I've never liked that idea and won't do it
sorry for the edit, hit the wrong button
Re: Mopar Performance die cast valve covers [Re: ZIPPY] #82634
07/01/08 12:30 PM
07/01/08 12:30 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
WITH Correct gormets no added holes needed
Re: Mopar Performance die cast valve covers [Re: 05dakota] #82635
07/01/08 01:00 PM
07/01/08 01:00 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
what? Sorry, I'm not following you. Unless your saying that you can get a grommet that will allow me to use that filler cap hole on one side? That would be cool, it doesn't really need two of those as far as I'm concerned. Do you have a part number for that?
I'm needing two, one for the little PCV and the other for the big one that goes to the breather.
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82636
07/01/08 02:08 PM
07/01/08 02:08 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
you dont need either fill cap, remove breather to add oil.
Re: Mopar Performance die cast valve covers [Re: 05dakota] #82637
07/01/08 02:09 PM
07/01/08 02:09 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ok, where to you get the grommets for this style of hole? Thanks.
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82638
07/01/08 02:15 PM
07/01/08 02:15 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
the one in the MP gormet kit works for the beather and i just get one from the HELP rack that works with the PCV .
Re: Mopar Performance die cast valve covers [Re: 05dakota] #82639
07/01/08 02:21 PM
07/01/08 02:21 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
That's how I did mine. Its been a while, but I think I got the grommets from Summit.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Mopar Performance die cast valve covers [Re: closer9] #82640
07/01/08 03:12 PM
07/01/08 03:12 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: Mopar Performance die cast valve covers [Re: Lefty] #82641
07/01/08 08:38 PM
07/01/08 08:38 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Forgive my ignorance but I see 6 different grommets on the Summit page. Which 2 grommets are needed?
Re: Mopar Performance die cast valve covers [Re: moparcanuk] #82642
07/02/08 07:02 AM
07/02/08 07:02 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I'm assuming the top two from Mopar? Thanks guys.
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82643
08/11/08 07:16 AM
08/11/08 07:16 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I went ahead and got the grommets from Mancini Racing. I also had the guys in the machine shop plunge one valve cover so I could keep one of the oil caps, but the grommets would of worked fine. Here some pictures and the part number from Mancini.
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82644
08/11/08 07:17 AM
08/11/08 07:17 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
pic two
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82645
08/11/08 07:17 AM
08/11/08 07:17 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
pic three
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82646
08/11/08 07:18 AM
08/11/08 07:18 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82647
08/11/08 09:55 PM
08/11/08 09:55 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Re: Mopar Performance die cast valve covers [Re: Robbins] #82648
08/11/08 10:04 PM
08/11/08 10:04 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
holesaw, dont remember exactly the p/n for the grommets i used. But they were from Mopar performance ( i think they sell two 'grommet kits')
(excuse the old pics)
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Mopar Performance die cast valve covers [Re: UCUDANT] #82649
08/12/08 05:09 AM
08/12/08 05:09 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I only got two baffles. So they went under the PVC and the breather on the passenger side. Hopefully that'll work.
Moparlee
Re: Mopar Performance die cast valve covers [Re: Robbins] #82650
08/12/08 10:46 AM
08/12/08 10:46 AM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
Spare parts!! Just kidding,I installed these valvecovers on the 383 in my Fury and forgot to put the baffles in.No real issues other than my breather caps fill up with oil over time then drips on to exhaust manifold. OOPS!
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
