E body battery cable question #82568
07/01/08 08:59 AM
07/01/08 08:59 AM
Anonymous OP
Anonymous OP
I need new battery cables for my 340 cuda. I can get chrysler PN 2983649 from Mancini but its says its a Positive battery cable for a B-RB engine.
What's the difference between a B-RB engine positive battery cable and a SB positive battery cable. Wouldn't they be the same length and look similar? Im not concerned about being exact here.
Also, they sell PN 2983778 for the negative batery cable. I assume that is for all engines.
Re: E body battery cable question #82569
07/01/08 11:22 AM
07/01/08 11:22 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
wont look like orginals.
Re: E body battery cable question #82570
07/01/08 11:34 AM
07/01/08 11:34 AM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
The only difference between an E-body big block cable and an E-body small block cable is the length, the small block cable is about 5-6 inches longer than the big block version, otherwise, they are the same.
Re: E body battery cable question [Re: rick@laysons] #82571
07/01/08 11:44 AM
07/01/08 11:44 AM
Anonymous OP
Anonymous OP
im not too concerned with the cables looking like the originals. I just need good canbles that will work
will the B-RB cables be long enough to hook up or am I going to need to spend $100 on a battery cable?
Re: E body battery cable question #82572
07/01/08 12:02 PM
07/01/08 12:02 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
All 3 still avail thru mopar
2983649 is big block
http://amhightechauto.com/images/parts/md649.jpg
2983648 is small block ( it supersedes )
http://amhightechauto.com/images/parts/md166.jpg
2983778 is negative all on except hemi
http://amhightechauto.com/images/parts/md778.jpg
