6.1 hemi , power mustang 2 rack. will the pump work? #825452
10/09/10 09:33 AM
10/09/10 09:33 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i have a 6.1 that is in a car with a mustang 2 power rack . will the stock 6.1 pump work with the mustang 2 rack?
Re: 6.1 hemi , power mustang 2 rack. will the pump work? [Re: dirt] #825453
10/09/10 12:53 PM
10/09/10 12:53 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
I was told no. The stock SRT8 pump has too much pressure for the rack. Bouchillon performance sells a fitting to make it compatible.
http://www.bouchillonperformance.com/61LHemiParts.asp ......bottom of this page, $27
Re: 6.1 hemi , power mustang 2 rack. will the pump work? [Re: rjsjea] #825454
10/15/10 02:16 PM
10/15/10 02:16 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i called them and they said that that fitting is to be used with the conversion pump they sell for $350 and it wont work on the original pump.
there has to be some way to use the original pump.
