440 timing *DELETED* *DELETED* #825248
10/08/10 08:32 PM
10/08/10 08:32 PM
Chesterfield, MIch
Cuda67 Offline OP
super street
Cuda67  Offline OP
super street
Chesterfield, MIch
Post deleted by Cuda67
Re: 440 timing [Re: Cuda67] #825249
10/08/10 10:11 PM
10/08/10 10:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
38
Re: 440 timing [Re: Cuda67] #825250
10/08/10 10:15 PM
10/08/10 10:15 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello 10 before top and 36 total!
Re: 440 timing [Re: Cuda67] #825251
10/08/10 11:57 PM
10/08/10 11:57 PM
No vacumn advance. Not a real stong engine. So what should the total advance be set at?
As said 36-38. But that may skew your initial (as is). I would find what it wants for initial w the vac gauge method then shorten the slots to get 36-38 total then play w the springs & get just a heavy enough spring combo to keep it just under the pinging point at WOT up thru the gears on your hottest/driest day. I would (highly) suggest doing these in order and slow timing may be why it is not up to par in addition to the CR possibly being too low (what is the cranking compression). Good luck w it & keep in mind that any ping you can HEAR is way too much.
