Page 1 of 3 1 2 3
Lakewood Traction Bars #824908
10/08/10 11:37 AM
10/08/10 11:37 AM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Why do I still see these on some '66-'73 leaf sprung MoPars? Am I missing something?
Re: Lakewood Traction Bars [Re: Moe] #824909
10/08/10 11:43 AM
10/08/10 11:43 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Not all owners of Mopars are Mopar-drivers....
Re: Lakewood Traction Bars [Re: BigBlockMopar] #824910
10/08/10 11:47 AM
10/08/10 11:47 AM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
If you put the snubber on the front spring hanger they work... we had them on a 70 Challenger with N-50s when I was a kid and the wheel hop stopped. With my shackles and air shocks, and lack of an adjustable pinion snubber, the spring wrap on my hoopty when doing burn outs is disgusting.
Plus they look cool... I hope to have mine on within a month after my axle swap.
The Blue Goose
My instagram: Bossride
Re: Lakewood Traction Bars [Re: BigBlockMopar] #824911
10/08/10 11:56 AM
10/08/10 11:56 AM
Under My Car
Mopar_Country Offline
Under My Car
Re: Lakewood Traction Bars [Re: Moe] #824912
10/08/10 05:39 PM
10/08/10 05:39 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Chryslers use asymmetrical springs (short in the front/long in the back) so the t-bars are less effective. Pinion snubbers work best on stock suspension, but any system that causes the rear to lift such as a superstock spring probably won't need a snubber either.
Re: Lakewood Traction Bars [Re: Moe] #824913
10/08/10 06:32 PM
10/08/10 06:32 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Because if you take the time to install the correctly they work very well.
Re: Lakewood Traction Bars [Re: slantzilla] #824914
10/08/10 07:53 PM
10/08/10 07:53 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
joe dirt gives them 2 thumbs up!!
Re: Lakewood Traction Bars [Re: Golden-Arm] #824915
10/08/10 08:16 PM
10/08/10 08:16 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Chip "Holeshot Horton" used them on his Duster and won many thousands of dollars racing.
Let's hear your scientific reasons for why traction bars wouldn't work ?
Re: Lakewood Traction Bars [Re: IronWolf] #824916
10/08/10 08:20 PM
10/08/10 08:20 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
There's a name I haven't heard in years. Since I lived in Sanford in the 80's.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Lakewood Traction Bars [Re: BradD] #824917
10/08/10 09:23 PM
10/08/10 09:23 PM
scratchnfotraction Offline
dog catchers just flat out work if installed correct
I had a peg leg rear axle that went from one long stripe to 2 short ones about 1.5 feet...on a 4 door fury no less
n-50s and traction bars was very effective in the day
granted it has come a long way since then and caltracs are shizzit nowdays
but some things are just cooler than hell!
I want a set for my truck with the flipflop on the rear axle
Re: Lakewood Traction Bars [Re: Moe] #824918
10/08/10 09:33 PM
10/08/10 09:33 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
If you're dead set on using traction bars, at least get the kind that take the place of the spring plate.
The kind you showed clamp to the leafs. That binds the suspension big-time and kills the ride.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Lakewood Traction Bars [Re: 340727dart] #824919
10/08/10 09:48 PM
10/08/10 09:48 PM
the clamp ons did flatin out the spring arch some and stiffin it up a good bit
but it had airshocks and the highjacker bunny sticker so that offset the ride factor
then there was the 10" wide keystones and n-50s that had to have those shock extentions from from JCwhitney to round out the package
Re: Lakewood Traction Bars [Re: scratchnfotraction] #824920
10/08/10 10:00 PM
10/08/10 10:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I seem to recall I never tightened the front u-bolt, only the rear. The front u-bolt was only there to keep the t-bar centered on the spring. The t-bar had to be long enough that the rubber bumper was just a hair behind the spring eye bolt and the bumper was short enough not to touch during normal driving.
So ... when you got on it the spring wound up and both the front u-bolt plate and the bumper hit the spring and planted the tire.
Re: Lakewood Traction Bars [Re: Stanton] #824921
10/08/10 10:27 PM
10/08/10 10:27 PM
Newfoundland Canada
Larry_Dart_360 Offline
Newfoundland Canada
Year ago I ran traction bars on my Dakota when I raced...I took off 2 tenths in my 60 foot with them... and then I ran them on my '71 dart...They made the car hook...They work...I took them off and installed a pinion snubber...It worked as well..but it hit when i went over rough spots in the road...I prefer the traction bars
Re: Lakewood Traction Bars [Re: Larry_Dart_360] #824922
10/08/10 10:35 PM
10/08/10 10:35 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
it cant realy be all that hard to weld some 1½x2" square steel with a bumpstop in one end to a set of old springpads, and if that works well then it woult be alot of fun looking at the guys with caltracs scratching there heads..
alitle oftopic but on the same plan how would it work having a tractionbar that is floatin on the front spring bolt? i understand it wont help plant the tire alot but wouldnt that help more stabilising the front springsegment?
i bet old style tractionbars is alot better than having nothing, i have seen 4 speedcars with low hanging tractionbars and its quite obvius that the front springsegments take a hard beating under power, its very clearly visible when watching the tractionbars when shifting gears
Re: Lakewood Traction Bars [Re: Larry_Dart_360] #824923
10/08/10 10:41 PM
10/08/10 10:41 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Ran them on my Dart just for fun (got them in a trade) and my sixty foot dropped. Most Mopar guys just automatically dismiss them because they heard from someone that they don't work, I prefer real world trial and error instead of hearsay.
Re: Lakewood Traction Bars [Re: dustergirl340] #824924
10/09/10 11:15 AM
10/09/10 11:15 AM
Conn.
b5 69 Offline
b5 69  Offline
Conn.
I put an old set on my car just to see, and I think they look cool. I know all about traction bars and mopars. So if you see bars on a mopar dont just assume the guy knows nothing. Maybe their just having some fun.Most mopar people who talk about traction bars probably have never bolted a set on.Im gonna leave them on for a while.
Re: Lakewood Traction Bars [Re: 340727dart] #824925
10/09/10 11:51 AM
10/09/10 11:51 AM
Under My Car
Under My Car
I'm not sure I agree with that, I put the bars on mine and it did stiffen the ride but it still rides decent. In fact I think it's better.
I believe the traction problem with Mopars and stock springs is spring wrap. With that said I would think that the traction bars will help, I know they did in my case. I have mine installed so the pad is under the front spring eye with 1/4 inch space I have seen a noticeable improvement in acceleration from a stop.
Re: Lakewood Traction Bars [Re: dustergirl340] #824926
10/09/10 05:18 PM
10/09/10 05:18 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I'm a firm believer in the "if it works then it works" philosophy (so is Yogi Beara), BUT I'm curious as to why thesuperstock guys/Ramchargers always used snubers instead and all the MP books state not to use tractions bar, only snubbers?
Re: Lakewood Traction Bars [Re: torkrules] #824927
10/09/10 07:43 PM
10/09/10 07:43 PM
Park Forest, IL
Park Forest, IL
Probably because they ran SS springs. Traction aids are not supposed to be used with them other than a snubber.
Page 1 of 3 1 2 3
