Broadcast Sheet Code...Help
#824793
10/07/10 11:55 PM
10/07/10 11:55 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
On the broadcast sheet its say the letter "S" Option Code S86 for a "soft padded center" steering wheel....Is this a TUFF wheel or what?? Anyone have a pic for this steering wheel if it ISNT the Tuff wheel?? Its for a 72 road runner..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: Broadcast Sheet Code...Help
[Re: Alaskan_TA]
#824800
10/08/10 04:36 PM
10/08/10 04:36 PM
Posts: 3,674 The Historic Hudson Valley
MONC
None of the factory ordering information shows the Tuff wheel being available on any E-Body regardless of model year.
I stand corrected.. A and B it is then. How bout C or F bodies??
[Re: 6bblgt]
#824802
10/08/10 05:31 PM
10/08/10 05:31 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
I believe this is correct for '72
I think you have two swapped around...S86 is the first one and S85 is the one with three horns.....
[Re: 72N96RR]
#824804
10/08/10 07:51 PM
10/08/10 07:51 PM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
it appears to me - that:
The 3-spoke w/padded horn button is STANDARD with the base RR bench seat interior - S85.
The 3-spoke w/padded center & 3 horn buttons is INCLUDED with A87 & "up-grade" bench seat or (additional OPTION) bucket seats - S86
What is on line 3 of the b'cast sheets for your RR & GTX? & what interior codes?
'72 RR interior - D6F6 Hamtramck-Historical
[Re: Texican]
#824805
10/08/10 07:55 PM
10/08/10 07:55 PM
6bblgt
Las Vegas, NV
Was there an option for S81 steering wheel or S15 suspension ?
Thx
1970 was the last year for the S81 - sport (woodgrain) 3-spoke steering wheel on a b-body.
S15 - was usually the upgraded suspension INCLUDED with axle packages on 340 or 383 cars. Not sure if it was used or orderable in '72. Do you have a b'cast sheet with "S15" on it.
[Re: 6bblgt]
#824807
10/09/10 08:55 PM
10/09/10 08:55 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
in line 3 under steering wheel is 25 and B5...horn pad 37 and B4...and line 12 under suspension-steering is S86 for the steering wheel...Hope that helps..
[Re: 6bblgt]
#824808
10/09/10 08:59 PM
10/09/10 08:59 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Thx
My 72 GTX has S13 for suspension...S25 for shocks...S41 for rear sway bar for the Dana..S77 power steering...and as stated S86 for the steering wheel..
[Re: 72N96RR]
#824809
10/09/10 09:04 PM
10/09/10 09:04 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
[Re: Alaskan_TA]
#824811
10/10/10 01:24 AM
10/10/10 01:24 AM
6bblgt
Las Vegas, NV
I don't have a '72 Parts Catalog, but here is a comparison from the '70-'71 version. (the difference for '71 b-bodies looks to be a darker blue) '72 b'cast - STEERING WHEEL 25 B5& HORN PAD 37 B4VS. '71 Parts Catalog - ***** STEERING WHEEL 19-30-4 WHEEL, Strg., W/Padded Horn Buttons - w/3 Spoke Horn Buttons - Blue 71 (A, B, & C-bodies) - 4025 GB7& 19-30-43 COVER, Strg. Wheel Center, w/3 Spoke Horn Buttons, - Blue 71 (A, B*, & C-bodies * non-Charger) - 4037 GB7FYI: (1971) the "cheap seats" 3-spoke steering wheel for use w/center padded horn button is 4054 GB7the woodgrain "PLYMOUTH" center for W/Padded Horn Buttons wheel is 3575 016
[Re: 6bblgt]
#824812
10/10/10 01:35 AM
10/10/10 01:35 AM
6bblgt
Las Vegas, NV
I have the following b'cast sheets: '72 Road Runner * STEERING WHEEL - 25/X9 * HORN PAD - 37/X9 * STRG. WHEEL S86 & D6X9 int. '72 Road Runner * STEERING WHEEL - 25/X9 * HORN PAD - 37/X9 * STRG. WHEEL S86 & D6XW int. '72 Charger SE * STEERING WHEEL - 25/X9 * HORN PAD - 37/X9 * STRG. WHEEL S87 same wheel & pad but S87? because it's a Charger?? '72 340 Duster * STEERING WHEEL - 54/Y6 * HORN PAD - 55/Y6 * STRG. WHEEL S85 "cheap wheel" '72 Swinger * STEERING WHEEL - 25/X9 * HORN PAD - 37/X9 * STRG. WHEEL S8_ WINDSOR built no S8_ code'72 Swinger * STEERING WHEEL - 25/F6 * HORN PAD - 37/F6 * STRG. WHEEL S8_ WINDSOR built no S8_ code '72 Charger Steering Wheels at Hamtramck-Historical ??
