68 RR trans #824495
10/07/10 08:20 PM
10/07/10 08:20 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
On a 4 speed trans for a 68 RR 383 how far out is the input shaft from the front of the case ? Ours is 8 5/8 " it seems like it is about 1/2" to long like it bottoms out in the crank before it gets to the bell housing ? Thanks
Re: 68 RR trans [Re: rc68rr] #824496
10/07/10 09:00 PM
10/07/10 09:00 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Is the motor original to the car ? That is to say, check to be sure the crank is drilled for the pilot bushing.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 68 RR trans [Re: 5wndwcpe] #824497
10/07/10 10:13 PM
10/07/10 10:13 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
The motor is out of a 69 charger it is drilled for a bushing. We have the orginal motor to be rebuilt. Thanks
Re: 68 RR trans [Re: rc68rr] #824498
10/07/10 10:41 PM
10/07/10 10:41 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
you have an automatic engine...mopar didnt finish drill the auto cranks...napa makes a special pilot bushing, and you have to cut about 1/2 in off the snout of the input...then it bolts right together
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 68 RR trans [Re: pnypwr] #824499
10/08/10 12:16 AM
10/08/10 12:16 AM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Will it be ok when I put the orginal motor back in or will I have to change out the inputshaft? Thanks
Re: 68 RR trans [Re: rc68rr] #824500
10/08/10 12:29 AM
10/08/10 12:29 AM
New York, USA
Chargerfan68 Offline
New York, USA
As long as you transfer the new roller bearing over from this crank or get another one and install in the original crank you can use the tranny on both.
