I put a new clutch in,,,, Centerforce dual friction diaphram in the 340,,,, adjusted it up all nice,,, and when I first started it I couldn't get it into gear, and if I started it in gear it would creep forward a bit and I can here the disc dragging between the plate and flywheel. I drove it a bit and it seems to have gotten a bit better, but still not 100%. Is this normal?? If not, what is wrong? If I tighten the adjustment anymore there won't be any clearance between the throwout bearing and pressure plate. Everything else checks out good,,, linkages, fork, return spring, etc.....
