broken A body fuel gauge #82421
06/30/08 09:19 PM
06/30/08 09:19 PM
duster408 Offline OP
I cant seem to get my fuel gauge to work correctly. I have a new sender and a new voltage limiter. With a full tank it only reads 1/4. I pulled it out of the tank and ran the sender up and down and no change. Any suggestions? thanks
Re: broken A body fuel gauge [Re: duster408] #82422
06/30/08 09:48 PM
06/30/08 09:48 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Make sure you have a good ground all the way back to the battery. The aftermarket sending units are very inaccurate also.
Re: broken A body fuel gauge [Re: duster408] #82423
06/30/08 09:50 PM
06/30/08 09:50 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
They work on resistance. That said you are either not getting a good solid ground, or proper supply voltage.
Re: broken A body fuel gauge [Re: Dart 340] #82424
06/30/08 09:52 PM
06/30/08 09:52 PM
what should the voltage be at the sender?
Re: broken A body fuel gauge [Re: duster408] #82425
06/30/08 11:13 PM
06/30/08 11:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Your test light should blink on and off at the sender wire. I believe a meter will read 5v. You should have a strap going from the metal outlet tube to the metal fuel line jumping the rubber hose as a ground for the sender.
Re: broken A body fuel gauge [Re: duster408] #82426
07/01/08 08:39 AM
07/01/08 08:39 AM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Wait, you have a voltage limiter or a capacitor on the gauge? Yes 5v is correct and it will pulse.
Do your other gauges work ok or are they off?
Re: broken A body fuel gauge [Re: Dart 340] #82427
07/01/08 09:00 AM
07/01/08 09:00 AM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Re: broken A body fuel gauge [Re: Dart 340] #82428
07/01/08 09:45 AM
07/01/08 09:45 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
What gauges do you have ralley or standard, i think the voltage reg on the ralley are built into the back of the fuel gauge, you have to remove the gauges and disasemble. standard gauges might just plug in the back
Re: broken A body fuel gauge [Re: ademon] #82429
07/01/08 10:06 PM
07/01/08 10:06 PM
the gauges are standard and the other gauges all work. I have tried running a ground wire all the way to the neg terminal on the battery and still no luck.
Re: broken A body fuel gauge [Re: duster408] #82430
07/01/08 11:05 PM
07/01/08 11:05 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I would check to make sure the float is ok, then try
adjusting the float lever and see if that helps. There is an abundance of crap repro senders out there. You could try a different one. It is quite imperative that the ground is good and solid, it makes all the difference in the world.
Re: broken A body fuel gauge [Re: Dart 340] #82431
07/02/08 01:13 PM
07/02/08 01:13 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
The sender out of the car should read about 8 ohms to 86 or so as you change the float level. Just use your meter and put one wire on the tube anywhere and the other on the terminal. Just a rheostat.
Finally dropped the tank on mine the other day and found that the float was sticking against the stock and not letting it move. I don't know why I didn't check this before I put it in. I did check that the rheostat was working but didn't pay attention to it slightly snagging at the bottom. Drats!
Now I am waiting on a new tube seal to come since I destroyed the brand new one taking it out.
The other gauges in the aforementioned thread seem to be working correctly now and I have done nothing. I guess it was just 30 years of sitting..
Re: broken A body fuel gauge [Re: duster408] #82432
07/02/08 04:46 PM
07/02/08 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
do you have the sending unit itself GROUNDED ???
