Re: pinion angle
[Re: 64Post]
#822649
10/07/10 06:42 PM
10/07/10 06:42 PM
Posts: 5,080 organ
maximum entropy
organ
°°°°°it... could... work...
Re: pinion angle
[Re: mod381]
#822656
10/10/10 10:22 AM
10/10/10 10:22 AM
Posts: 878 hudson valley n.y.
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
I like to see 2 degrees negative for a street car.
If the transmission slopes downward 5 degrees toward the rear, the pinion should slope upward 2 degrees toward the front.
This is referred to as 3 degree negative pinion angle. I consider 4 degree negative to be the maximum for a true street car. thank you doctor diff....thats what i am going to do.....i will report back when i am done with the test drive.....3 degrees negative pinion angle
I see you wrote car worked good. Is this what you have it set at?
yes....i sloped up the pinion 2 degrees positive.....no vibration while cruisin on the street and perfect at the track....thanks to dr diff.....hes the man ![](/ubbthreads/images/graemlins/thumbs.gif)
