pinion angle #822627
10/05/10 07:50 PM
10/05/10 07:50 PM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
hi guys....just wanted to ask a question....i am going up to the track saturday and i am trying to get my rear set up right.....95% of the time i drive it on the street and maybe hit the track 4-5 times a year......right now with the suspension loaded and the car level my trans is -5 degrees and my pinion is 0 degrees....i am running super stock springs on my roadrunner with a pinion snubber about 1 inch from the floor...i am cutting off and rewelding new axle saddles since the rear is out of square with the center line of the car.....should i minus the pinion ?? degrees
if anyone could help me out that would be great
thanks
george
Re: pinion angle [Re: GEORGE68HEMIRR] #822628
10/05/10 08:03 PM
10/05/10 08:03 PM
organ
maximum entropy Offline
organ
at the risk of being flagellated by the 'pinion master, -5 is ok. i run mine about -6 on the street with ss springs and it has been very reliable. i do get a little vibration at high speed cruise, but that's just the way it's got to be until i backhalf it and get the angle closer to zero.
Re: pinion angle [Re: maximum entropy] #822629
10/05/10 08:18 PM
10/05/10 08:18 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
so maybe i should minus the pinion angle down to -1 or maybe -2 since i am installing new saddles anyway?
Re: pinion angle [Re: GEORGE68HEMIRR] #822630
10/05/10 09:01 PM
10/05/10 09:01 PM
organ
organ
-7 is near ideal with ss springs. it won't be the smoothest at high speed cruise, and it may need ujoints every couple of years, but i have had no problems at -6 (actually more like -6.5).
Re: pinion angle [Re: maximum entropy] #822631
10/05/10 09:26 PM
10/05/10 09:26 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
so if i use the pinion degree indicator on my pinion yoke to measure degrees i would need plus 2 degrees on my pinion to get minus 2 degrees nose down which is ideal for the street and occasionally for the track.....what do you think?
Re: pinion angle [Re: GEORGE68HEMIRR] #822632
10/06/10 12:11 AM
10/06/10 12:11 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No, plus 2* pinion will get you 3* nose down pinion angle compared to your 5* down tranny centerline angle. mike
Re: pinion angle [Re: Sport440] #822633
10/06/10 02:04 AM
10/06/10 02:04 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
your right,,,,thanks mike
Re: pinion angle [Re: GEORGE68HEMIRR] #822634
10/06/10 12:04 PM
10/06/10 12:04 PM
organ
organ
i wouldn't run -2 with ss springs at the track. that's a driveline killer.
Re: pinion angle [Re: maximum entropy] #822635
10/06/10 12:31 PM
10/06/10 12:31 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Normally, a true 4 degree negative pinion angle is the maximum I recommend. This is relative to the transmission center-line, not to the driveshaft or the ground.
I like to see 2 degrees negative for a street car.
Re: pinion angle [Re: Sport440] #822636
10/06/10 08:34 PM
10/06/10 08:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
BTW: to make a "degree" sign, press & hold the ALT key, while typing 0 1 7 6
Boffin Emeritus
Re: pinion angle [Re: polyspheric] #822637
10/06/10 10:01 PM
10/06/10 10:01 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Okay 45 ALT key 0176
45, nothing
Okay 45 ALT key 0 1 7 6
45, nothing, alright quit screwing with me.
Re: pinion angle [Re: DoctorDiff] #822638
10/06/10 11:47 PM
10/06/10 11:47 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
was talking to a guy who sets-up ladder bar/4 links....chevy guy....and he said.....level car suspension loaded.....check the degrees on the driveshaft which is minus 1 degree and the pinion is 0 degrees....for me to lower or minus the pinion to 2 degrees which would give me minus 3 degrees.....he said never raise or plus the degrees of the pinion because of spring wrap up.......what do you think?.....and i will be using a pinion snubber
Re: pinion angle [Re: GEORGE68HEMIRR] #822639
10/07/10 12:38 AM
10/07/10 12:38 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That method only works sometimes, depending on the angle of the engine/transmission.
Pinion angle is the relationship between the transmission centerline and the pinion centerline. Ideally, you want the pinion to become relatively parallel to the transmission as the pinion swings upward when the car is under power. This is how U-joints are designed to run.
In other words, make the pinion parallel to the transmission as a base-line, then rotate the pinion downward 2-4 degrees.
Don't worry about the operating angle of the driveshaft unless the vehicle is severely lowered or raised, causing the U-joints to bind.
Re: pinion angle [Re: Sport440] #822640
10/07/10 01:14 AM
10/07/10 01:14 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
45, nothing
45º....45º....45º... 45º
Re: pinion angle [Re: 64Post] #822641
10/07/10 01:35 AM
10/07/10 01:35 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
45, nothing
Allright, Even if I do figure out how to create a degree symbol. Im still going to just use this
45*... 45*...45*...45* Get used to it. mike
Re: pinion angle [Re: Sport440] #822642
10/07/10 11:01 AM
10/07/10 11:01 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Every time I read one of these pinion angle posts my right nipple starts to bleed.
Measure trans. Make pinion the same, as in parallel. Tip the front down an additional 5*. That's 5* pinion angle. Done like dinner.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: pinion angle [Re: DoctorDiff] #822643
10/07/10 11:34 AM
10/07/10 11:34 AM
Az
Crizila Offline
Crizila  Offline
Az
Over 4 and you are asking for a drive line rumble on the street.
Fastest 300
Re: pinion angle [Re: Crizila] #822644
10/07/10 12:25 PM
10/07/10 12:25 PM
organ
organ
true
Re: pinion angle [Re: DoctorDiff] #822645
10/07/10 03:26 PM
10/07/10 03:26 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
If the transmission slopes downward 5 degrees toward the rear, the pinion should slope upward 2 degrees toward the front.
This is referred to as 3 degree negative pinion angle. I consider 4 degree negative to be the maximum for a true street car.
thank you doctor diff....thats what i am going to do.....i will report back when i am done with the test drive.....3 degrees negative pinion angle
Re: pinion angle [Re: GEORGE68HEMIRR] #822646
10/07/10 04:32 PM
10/07/10 04:32 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
