Re: Back glass caulked in, BEST way to remove?
[Re: Charger_440]
#822496
10/05/10 05:36 PM
10/05/10 05:36 PM
Posts: 3,378 KY USA
mopargem
KY USA
Thin wire like guitar or piano, I use welding wire but it breaks easy, one person on each end and wire saw it right out, works every time for me. I usually also cut the outside with a razor knife first down to the pinchweld.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: Charger_440]
#822500
10/06/10 08:00 AM
10/06/10 08:00 AM
Challenger 1
Cincinnati, Ohio
This stuff is white/ beige. Its over top of the original stuff. It's some serious stuff. I can't even mount my rear window trim bcse it's hopped up the clips, etc
This tool will cut through anything, including rubber gaskets. By using it there is no chance of breakage, unlike the tool shown above.
[Re: Challenger 1]
#822501
10/06/10 10:40 AM
10/06/10 10:40 AM
Posts: 304 Ohio
LS-300
Ohio
The last one I removed had the sam black goop you refered to. I used a puddy knife and worked slowly around the window. Didn't take long.
1979 Chrysler 300
1968 Barracuda project
[Re: LS-300]
#822502
10/06/10 04:22 PM
10/06/10 04:22 PM
Posts: 715 Tulsa, Oklahoma
Charger_440
Tulsa, Oklahoma
so when i get it out, whats the best way to get that crap off of the glass? hte channel, thats a little easer, i can really scrape against it if i need to, but the glass....eesh! any suggestions?
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
