Back glass caulked in, BEST way to remove? #822494
10/05/10 05:17 PM
10/05/10 05:17 PM
Tulsa, Oklahoma
Charger_440 Offline OP
Tulsa, Oklahoma
the back glass on my 74 is caulked in with something thats rock hard and has a very tenacious bond. this is something that someone has done, not factory sealant.
i need suggestions on the best way to remove it, its all around the trim clip studs and on the glass, and everything.there is no way on earth this window was gonna leak! lol.
Re: Back glass caulked in, BEST way to remove? [Re: Charger_440] #822495
10/05/10 05:33 PM
10/05/10 05:33 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 73 Challenger was sort of the same way. It was black and oozed all over everything. It wasn't extremely hard though once you got past the outer crust. It was factory, on my car anyway. I know it wasn't the tape that people use to reinstall the glass.
I poked a hole through the caulking and inserted some braided metal wire through the hole. My dad and I sawed all the way around the glass.
Re: Back glass caulked in, BEST way to remove? [Re: Charger_440] #822496
10/05/10 05:36 PM
10/05/10 05:36 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Thin wire like guitar or piano, I use welding wire but it breaks easy, one person on each end and wire saw it right out, works every time for me. I usually also cut the outside with a razor knife first down to the pinchweld.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Back glass caulked in, BEST way to remove? [Re: Charger_440] #822497
10/05/10 05:44 PM
10/05/10 05:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Most auto parts stores sell a specially braided brass wire for this job, can't/won't hurt the glass.
Re: Back glass caulked in, BEST way to remove? [Re: Challenger 1] #822498
10/06/10 01:50 AM
10/06/10 01:50 AM
Tulsa, Oklahoma
Tulsa, Oklahoma
This stuff is white/ beige. Its over top of the original stuff. It's some serious stuff. I can't even mount my rear window trim bcse it's hopped up the clips, etc
Re: Back glass caulked in, BEST way to remove? [Re: Challenger 1] #822499
10/06/10 04:44 AM
10/06/10 04:44 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Here's a link to the style windshield cut out tool that I use.
Windshield tool on ebay
Re: Back glass caulked in, BEST way to remove? [Re: Charger_440] #822500
10/06/10 08:00 AM
10/06/10 08:00 AM
Cincinnati, Ohio
Cincinnati, Ohio
This tool will cut through anything, including rubber gaskets. By using it there is no chance of breakage, unlike the tool shown above.
Re: Back glass caulked in, BEST way to remove? [Re: Challenger 1] #822501
10/06/10 10:40 AM
10/06/10 10:40 AM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
The last one I removed had the sam black goop you refered to. I used a puddy knife and worked slowly around the window. Didn't take long.
1979 Chrysler 300 1968 Barracuda project
Re: Back glass caulked in, BEST way to remove? [Re: LS-300] #822502
10/06/10 04:22 PM
10/06/10 04:22 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
so when i get it out, whats the best way to get that crap off of the glass? hte channel, thats a little easer, i can really scrape against it if i need to, but the glass....eesh! any suggestions?
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
Re: Back glass caulked in, BEST way to remove? [Re: Charger_440] #822503
10/07/10 10:17 AM
10/07/10 10:17 AM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
bug and tar remover.
Re: Back glass caulked in, BEST way to remove? [Re: LS-300] #822504
10/07/10 03:07 PM
10/07/10 03:07 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Long wire rope thin cable and a pair of gloves. Sometimes it takes 2 people though. If you think the glass is loose enough to "push it out" the rest of the way without cutting it loose first, you will break the glass.
