Re: Automatic floor shifters
[Re: Mr.Yuck]
#821404
10/04/10 11:02 AM
10/04/10 11:02 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Another Vote for the Quicksilver unit. I run it in all my cars. The rachet is self-centering meaning it always goes back to center(no matter which gear you are in), it has a reverse lockout, Seems impossible to steal as nobody but me seems to know how it works(it is easy), and I believe if I use the same shifter in every car, it might prevent me from getting confused.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: Diplomat360]
#821407
10/04/10 02:19 PM
10/04/10 02:19 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I put the B&M Quicksilver in my coupe as well...seems alright so far...but the car isn't finished yet.
Q for you guys running this. When putting the shifter in 'D'...does it automatically drop down into the ratchet mode for you, or do you have to push the shifter handle down?
Mine drops down right away, but looking at the mechanism it looks like it should stay up and then require me to push it down if I want it to go into ratchet mode.
You pull it into D and it's in ratchet mode. You can't go up into park unless you are in D. Then you lift it out of the gate and move it up. I have a reverse Man valve body so I pull back on the stick to go up...you'll simply nudge it up from 1st if you want to shift manually.
[Re: Diplomat360]
#821408
10/04/10 03:18 PM
10/04/10 03:18 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
It should drop down.
I ran a QuickSilver. I liked it. Now I have a B&M Pro ratchet. I like it as well.
[Re: abodyjoe]
#821416
10/05/10 11:16 PM
10/05/10 11:16 PM
Posts: 1,324 Western Pa
joewhite440
Western Pa
i went with the CHEETAH SCS. one of the better decisions i have made. operates very smooth and the thing i think i like best is how the cable runs around the rear of the tans. keeps it away from all the heat and other crap that is near the front of the trans..
Best shifter I ever ran. Had them in different cars!
[Re: joewhite440]
#821417
10/06/10 12:57 AM
10/06/10 12:57 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Another vote for the Quicksilver, here. I like the way it looks and feels, and it works great.
[Re: StealthWedge67]
#821418
10/06/10 06:53 PM
10/06/10 06:53 PM
Posts: 892 Illinois
StrkrDart69
Illinois
My shifter
