Re: Shifter hits the dash...
[Re: Silverbullet2]
#821356
10/04/10 03:24 PM
10/04/10 03:24 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Does Hurst make a flat stick handle for the comp plus shifter besides the pistol grip for 68 and 69 console equipped b-bodies? I bought a new shifter and a #4084 handle and thought I was good but it hits the dash in first and third. Got to thinking and about every time I've seen this combination it's been on a 66-67, which probably has a tighter dash? I noticed the console pistol grip has a dogleg my 4084 handle doesn't. Wouldn't take much but it would probably be enough to ruin the chrome. Any ideas?
First off 68 and 69 NEVER had a pistol grip unless someone installed it. Starting in 1970 there was a SPECIAL shifter box that had longer arms out the bottom that shortened the throw , it's 70 B body ONLY, you need one of them.
I thought I just saw one for sale in the transmission for sale section?
[Re: thehemikid]
#821359
10/04/10 03:41 PM
10/04/10 03:41 PM
JohnRR
U.S.S.A.
...Is this the one?
Yes I was just going to link that picture.
[Re: Silverbullet2]
#821360
10/04/10 03:42 PM
10/04/10 03:42 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...Could you post a pic of your lever?
[Re: Silverbullet2]
#821363
10/04/10 11:48 PM
10/04/10 11:48 PM
Posts: 4,774 Star Idaho
67vertman
Star Idaho
There are a few different shifter mounting plates. Mabe you could find one that brings the shifter back some.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#821364
10/05/10 10:05 AM
10/05/10 10:05 AM
JohnRR
U.S.S.A.
It would be nice if it were that simple , the bolt patterns on the trans have different spacing so only a mount made to fit in that specific spot will work .
That's a good deal on Russ' shifter box, and the PROPER fix.
[Re: Silverbullet2]
#821368
10/06/10 09:36 AM
10/06/10 09:36 AM
JohnRR
U.S.S.A.
Hurst Shifters (username) on ebay is selling a competition plus kit for console 66-69 b-bodies. I'm curious as to which handle they're using. I can't get the photo to load. If it's the 4084 I beg to differ. I might send him a message and ask. Thanks for the help fellas!
Link ?
Why not just buy the right shifter box that was posted above ?
[Re: JohnRR]
#821369
10/06/10 01:15 PM
10/06/10 01:15 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
When I installed a 71 B-body bench seat pistol grip in my 64 Polara with a console, it would hit the dash in 1st and 3rd. I used a new Hurst Comp plus, but not the one you guys are talking about. I drilled a hole just to the rear of the bottom hole in the handle (bolt in style) to lean it back a little then welded up the front hole so it wouldn't slip and that fixed the probelm. No cutting the handle. Been in there for 5k miles and LOTS of gear slams!
Jeff Adams
64 426 Polara
