Shifter hits the dash... #821354
10/04/10 06:42 AM
10/04/10 06:42 AM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
Does Hurst make a flat stick handle for the comp plus shifter besides the pistol grip for 68 and 69 console equipped b-bodies? I bought a new shifter and a #4084 handle and thought I was good but it hits the dash in first and third. Got to thinking and about every time I've seen this combination it's been on a 66-67, which probably has a tighter dash? I noticed the console pistol grip has a dogleg my 4084 handle doesn't. Wouldn't take much but it would probably be enough to ruin the chrome. Any ideas?
Re: Shifter hits the dash... [Re: Silverbullet2] #821355
10/04/10 02:58 PM
10/04/10 02:58 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Can you "pie-cut" it below the boot and reweld it? Just throwing it out there...
Re: Shifter hits the dash... [Re: Silverbullet2] #821356
10/04/10 03:24 PM
10/04/10 03:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
First off 68 and 69 NEVER had a pistol grip unless someone installed it. Starting in 1970 there was a SPECIAL shifter box that had longer arms out the bottom that shortened the throw , it's 70 B body ONLY, you need one of them.
I thought I just saw one for sale in the transmission for sale section?
Re: Shifter hits the dash... [Re: Jwilli500] #821357
10/04/10 03:28 PM
10/04/10 03:28 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...If the lever's below the pivot were longer, there would be a shorter stroke above at the lever. Does HURST or anyone else make a shorter stroke "SHIFTER" out there. I'm not going to have the Shifter-to-dash problem you have, but I'd like a little shorter stroke my self.
Re: Shifter hits the dash... [Re: thehemikid] #821358
10/04/10 03:39 PM
10/04/10 03:39 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Is this the one?
Re: Shifter hits the dash... [Re: thehemikid] #821359
10/04/10 03:41 PM
10/04/10 03:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
...Is this the one?
Yes I was just going to link that picture.
Re: Shifter hits the dash... [Re: Silverbullet2] #821360
10/04/10 03:42 PM
10/04/10 03:42 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Could you post a pic of your lever?
Re: Shifter hits the dash... [Re: JohnRR] #821361
10/04/10 07:24 PM
10/04/10 07:24 PM
Pittsfield, Mass.
Russ_Davis Offline
Russ_Davis  Offline
Pittsfield, Mass.
Hey thats my shifter............
Re: Shifter hits the dash... [Re: Russ_Davis] #821362
10/04/10 10:33 PM
10/04/10 10:33 PM
North Carolina, USA
North Carolina, USA
Yeah I know the pistol grip was a 1970 only, I was just noticing the difference in how the handle is bent. I think the idea of pie cutting the stick might work, but it probably needs to be done above the boot to keep the boot/console alignment right. I'm thinking a little down there will make a considerable difference at the knob end. I've got an extra #4084 handle that needs rechroming anyway. Might experiment with it!
Re: Shifter hits the dash... [Re: Silverbullet2] #821363
10/04/10 11:48 PM
10/04/10 11:48 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
There are a few different shifter mounting plates.
Mabe you could find one that brings the shifter back some.
My Monster are real!
Living within your means makes life pretty easy.
Re: Shifter hits the dash... [Re: 67vertman] #821364
10/05/10 10:05 AM
10/05/10 10:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It would be nice if it were that simple , the bolt patterns on the trans have different spacing so only a mount made to fit in that specific spot will work .
That's a good deal on Russ' shifter box, and the PROPER fix.
Re: Shifter hits the dash... [Re: Jwilli500] #821365
10/05/10 10:50 AM
10/05/10 10:50 AM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
I've done it in my 70 RR. Best & Cheapest way to go IMO.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Shifter hits the dash... [Re: Silverbullet2] #821366
10/05/10 02:29 PM
10/05/10 02:29 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Aaahhh! I didnt catch that you had a console. I'm not a 4-speed guy anyways.
Re: Shifter hits the dash... [Re: Jwilli500] #821367
10/05/10 10:29 PM
10/05/10 10:29 PM
North Carolina, USA
North Carolina, USA
Hurst Shifters (username) on ebay is selling a competition plus kit for console 66-69 b-bodies. I'm curious as to which handle they're using. I can't get the photo to load. If it's the 4084 I beg to differ. I might send him a message and ask. Thanks for the help fellas!
Re: Shifter hits the dash... [Re: Silverbullet2] #821368
10/06/10 09:36 AM
10/06/10 09:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Link ?
Why not just buy the right shifter box that was posted above ?
Re: Shifter hits the dash... [Re: JohnRR] #821369
10/06/10 01:15 PM
10/06/10 01:15 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
When I installed a 71 B-body bench seat pistol grip in my 64 Polara with a console, it would hit the dash in 1st and 3rd. I used a new Hurst Comp plus, but not the one you guys are talking about. I drilled a hole just to the rear of the bottom hole in the handle (bolt in style) to lean it back a little then welded up the front hole so it wouldn't slip and that fixed the probelm. No cutting the handle. Been in there for 5k miles and LOTS of gear slams!
Jeff Adams 64 426 Polara
Re: Shifter hits the dash... [Re: Ledman_70] #821370
10/06/10 04:58 PM
10/06/10 04:58 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...neat fix.
Re: Shifter hits the dash... [Re: thehemikid] #821371
10/12/10 09:46 AM
10/12/10 09:46 AM
North Carolina, USA
North Carolina, USA
I did mssg the ebay guy and his shifter uses that same handle/stick. He says he's sold hundreds of them and never had an issue. To give the devil his due it did go fully into gear but the shifter was touching the dash. A friend of mine said why not just wrap the handle in rags and put it in a press. I decided to give it a shot. Fogged the chrome just a little but I have a couple inches now with a round knob and a little less with a T handle. I think it'll work. Thanks!
