Switching to 3.73's what can I expect? #821042
10/03/10 07:29 PM
10/03/10 07:29 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
I an replacing my rearend with another, and it has 3.73's in it. Stock rear with 2.73s or whatever was in it. Its a dog off the line, but gets up to speed and cruises nice.
Mild 360 with Offy intake, 650 Holley, TTI headers, mild cam, stock 904 with the 318 TQ... no tach, but it doesn't sound like it's running that hard around 75-80... will I still be able to roadtrip comfortably without doing any harm? How much of a difference should it really make?
On the plus side, I am looking forward to some two-wheeled burnouts for a change.
The Blue Goose
My instagram: Bossride
Re: Switching to 3.73's what can I expect? [Re: BossRide] #821043
10/03/10 07:40 PM
10/03/10 07:40 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Use this and you will have your answer. http://vexer.com/automotive-tools/speed-rpm-calculator
Re: Switching to 3.73's what can I expect? [Re: BossRide] #821044
10/03/10 07:40 PM
10/03/10 07:40 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
For the first year, you'll constantly be checking to see if you are in 2nd. gear. Seriously.
Re: Switching to 3.73's what can I expect? [Re: Commando1] #821045
10/03/10 07:46 PM
10/03/10 07:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I agree & to really experience it before swapping gears take your car for a long drive & leave it in second gear... 2.76 (likely your current gear) x 1.45 (the ratio of 2nd gear) = 4.02 close enough to 3.73 you'll get the idea...
Re: Switching to 3.73's what can I expect? [Re: BossRide] #821046
10/03/10 08:01 PM
10/03/10 08:01 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I run 3.73's behind my 383, with 28" tall tires and a 2200 RPM torque converter. I recently took a 400 mile round trip. Cruised at 3,000 RPM's on the interstate which is about 65 mph. No problems. Been running these gears for several years. I like 'em.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Switching to 3.73's what can I expect? [Re: Junky] #821047
10/03/10 08:07 PM
10/03/10 08:07 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
Hmmm.... but it will get out of it's own way off the line, though, right?
I wonder if I can get an Overdrive trans? LOL... I like to drive fast.
The Blue Goose
Re: Switching to 3.73's what can I expect? [Re: BossRide] #821048
10/03/10 08:46 PM
10/03/10 08:46 PM
Under My Car
Mopar_Country Offline
Under My Car
You should notice quite a difference from a standstill, much more responsive.
Re: Switching to 3.73's what can I expect? [Re: Mopar_Country] #821049
10/03/10 09:14 PM
10/03/10 09:14 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Your cam and converter stall speed and rear tire height ALL play into this equation. You should notice some performance improvement now, but ALL the above components MUST match the rear gear ratio before you can run with the big dogs.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Switching to 3.73's what can I expect? [Re: GO_Fish] #821050
10/03/10 10:08 PM
10/03/10 10:08 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
Interesting...
My cam specs:
936P
Intake, exhaust lift: .443/.465
280/290-advertised duration
Intake and exhaust duration @ 50: 214/224
61º overlap
107º lobe center
Tires are 15x10 275/60/15, and the torque converter is the stock one from the 318 on a B&M flex plate....
How does all that fare with the new gear, and what would you change? Is there anything seriously wrong? I know it's a big car, and I take long trips... I'm not looking to run in the 10s. just have some reliable fun. It's a one-legged dog right now until about 70mph...
The Blue Goose
Re: Switching to 3.73's what can I expect? [Re: BossRide] #821051
10/03/10 10:29 PM
10/03/10 10:29 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
to be fast at the track, you want your converter stall speed rpm to be close to your maximum horsepower rpm. When you leave the green light, you want your stall speed right at maximum horsepower (so the engine doesn't need to spool up to max hp, you are already there). You shouldn't be traction limited with a early 70's B body, they were made for extreme wide tires. Your stock converter is probably your limiting factor right now, the converter is stalling well before your motor is making maximum power. On a budget, step up to a mopar 175k converter. If you can get an extra $600, step up to a good performance converter. You'll need to add a big trans cooler (if you haven't already) to keep things cool, but she should then jump out of the hole, WAY before 70 mph.
Re: Switching to 3.73's what can I expect? [Re: GO_Fish] #821052
10/04/10 10:31 PM
10/04/10 10:31 PM
Central NC
gch Offline
gch  Offline
Central NC
It will feel like you hit it with a 100 shot.
You may have to retune the carb somewhat for optimal performance.
You will be spinning a lot more rpm on the highway and will lose a lot of topend potential.
Re: Switching to 3.73's what can I expect? [Re: gch] #821053
10/04/10 11:16 PM
10/04/10 11:16 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
Would a 3.23 make any difference? Is that a nice average type of gear for a car my size? Like I said, I don't want to go drag racing, and I make frequent road trips... but the 2.70s are a dog until it gets rolling.
The Blue Goose
Re: Switching to 3.73's what can I expect? [Re: BossRide] #821054
10/04/10 11:32 PM
10/04/10 11:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
3.23 & a good all around gear.. Cruises well & not terrible around town.. With a smallblock I'd probably consider going 3.55...
Re: Switching to 3.73's what can I expect? [Re: 1_WILD_RT] #821055
10/05/10 01:25 AM
10/05/10 01:25 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
3.73 ratio will be great for street performance but you'll still be able to cruise the highways.
Good choice.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Switching to 3.73's what can I expect? [Re: MY340] #821056
10/05/10 02:21 AM
10/05/10 02:21 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Play with the calculator stumpy linked you to. Really building an overdrive transmission is the only way to get the best of both. With a combo like yours and a 727 or 904, everything else is a compromise.
Re: Switching to 3.73's what can I expect? [Re: DaytonaTurbo] #821057
10/05/10 09:41 AM
10/05/10 09:41 AM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
I drove to the shop in 2nd, like suggested, and while it was very peppy I felt like I was over-running the engine for the way I drive. I make frequent road trips on roads where 75-80 is normal and don't think I would like the 3.73s... those were in an axle I was going to swap out my 8 1/4 with... but then the guy at the shop had a buddy with a big block/auto 73 RR parts car that is missing the engine and trans, but has the 8 3/4 rear and front and rear sway bars, hood, passenger side mirror, and a ton of other stuff I can use, so I'm buying it. I was told that the rearend has 3.23s but they don't know if it's a sure grip or not. That would be cool if it was.
The Blue Goose
Re: Switching to 3.73's what can I expect? [Re: BossRide] #821058
10/05/10 09:56 AM
10/05/10 09:56 AM
Commando1 Offline
Commando1  Offline
Go with the 3.23!
Set up the engine and tranny accordingly.
You'll be one happy cruiser.
