how to figure out volume increase #819422
10/01/10 09:55 PM
10/01/10 09:55 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
say from a .140 orifice to a .160
how much more volume can it flow
thanks
WAXER
Re: how to figure out volume increase [Re: QWK_ENUF] #819423
10/01/10 09:57 PM
10/01/10 09:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
easy .020 more
Re: how to figure out volume increase [Re: Quicktree] #819424
10/01/10 10:04 PM
10/01/10 10:04 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
quicktree you slay me but i am looking for a formula
WAXER
Re: how to figure out volume increase [Re: QWK_ENUF] #819425
10/01/10 10:12 PM
10/01/10 10:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Ok you asked - .160-.140=.020 sorry
Re: how to figure out volume increase [Re: QWK_ENUF] #819426
10/01/10 11:50 PM
10/01/10 11:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The easy math:
New^2 ÷ old^2
.160^2 ÷ .140^2 = +36%
But it's not that simple. The Poiseville effect increases it slightly, but the pressure differential is slightly lower - and even that's if your pump can always supply the same pressure.
Holley probably has a comparison somewhere.
Boffin Emeritus
Re: how to figure out volume increase [Re: QWK_ENUF] #819427
10/02/10 12:05 AM
10/02/10 12:05 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It will flow the same volume, it will just take longer
The increase in area is
PI*(0.160/2)^2 - PI*(0.140/2)^2 = ?
0.0201062 - 0.0153938 = 0.0047124
The increase in area is about 30.6% (If I did the math right?)
Re: how to figure out volume increase [Re: QWK_ENUF] #819428
10/02/10 01:20 AM
10/02/10 01:20 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
On the Barry Grant website, they publish a jet flow chart . It only goes up to a holley 100 size jet.
The chart shows jet dia. to flow curve is steeper than cross sectional areas would indicate.
Years ago someone posted a formula. I think it was b1Ken?
dia.^2.2 x 142200 = jet flow
The barry grant curve however is not exactly inline with this formula.
Using this formula shows a 34.1 % flow increase as opposed to a 30.6% increase for just cross sectional area. (.160" dia over .140" dia)
Re: how to figure out volume increase [Re: ToddP] #819429
10/02/10 11:13 AM
10/02/10 11:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Good info. I searched around and found a few other posts with the jet flow calculation. Seems it may relate closer to actual flow taking things like surface tension of the fuel and flow friction into account?
either way I think comparing the change as percent difference seems to be more useful to me than the actual area or flow numbers.
