how to figure out volume increase
#819422
10/01/10 09:55 PM
10/01/10 09:55 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
say from a .140 orifice to a .160
how much more volume can it flow
thanks
WAXER
Re: how to figure out volume increase
[Re: QWK_ENUF]
#819425
10/01/10 10:12 PM
10/01/10 10:12 PM
Quicktree
quicktree you slay me but i am looking for a formula
Ok you asked - .160-.140=.020 sorry
[Re: QWK_ENUF]
#819426
10/01/10 11:50 PM
10/01/10 11:50 PM
Posts: 4,211 New York
polyspheric
New York
The easy math: New^2 ÷ old^2 .160^2 ÷ .140^2 = +36%
But it's not that simple. The Poiseville effect increases it slightly, but the pressure differential is slightly lower - and even that's if your pump can always supply the same pressure. Holley probably has a comparison somewhere.
Boffin Emeritus
[Re: QWK_ENUF]
#819427
10/02/10 12:05 AM
10/02/10 12:05 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
It will flow the same volume, it will just take longer The increase in area is PI*(0.160/2)^2 - PI*(0.140/2)^2 = ? 0.0201062 - 0.0153938 = 0.0047124 The increase in area is about 30.6% (If I did the math right?)
[Re: QWK_ENUF]
#819428
10/02/10 01:20 AM
10/02/10 01:20 AM
Posts: 684 Milwaukee
ToddP
super street
super street
Milwaukee
On the Barry Grant website, they publish a jet flow chart . It only goes up to a holley 100 size jet.
The chart shows jet dia. to flow curve is steeper than cross sectional areas would indicate.
Years ago someone posted a formula. I think it was b1Ken? dia.^2.2 x 142200 = jet flow
The barry grant curve however is not exactly inline with this formula.
Using this formula shows a 34.1 % flow increase as opposed to a 30.6% increase for just cross sectional area. (.160" dia over .140" dia)
[Re: ToddP]
#819429
10/02/10 11:13 AM
10/02/10 11:13 AM
451Mopar
Aurora, Colorado
Good info. I searched around and found a few other posts with the jet flow calculation. Seems it may relate closer to actual flow taking things like surface tension of the fuel and flow friction into account? either way I think comparing the change as percent difference seems to be more useful to me than the actual area or flow numbers.
