Master cut off switch on a duster #819187
10/01/10 06:22 PM
10/01/10 06:22 PM
Hinterland SE Qld Aust
SG duster Offline OP
What are you duster racers using for a cut off switch & where have you mounted them?
Re: Master cut off switch on a duster [Re: SG duster] #819188
10/01/10 07:56 PM
10/01/10 07:56 PM
Locomotion Offline
Locomotion  Offline
I have a Dart Sport but my set-up should also work on a Duster. I have a push/pull rod coming out below the taillights, just above the rear bumper. The hole is somewhat concealed. I just had to fabricate the linkage to the regular master cut-off switch mounted inside off of my weight boxes. Rod and clamps are out of aluminum and easier to fabricate at home.
Re: Master cut off switch on a duster [Re: SG duster] #819189
10/01/10 10:44 PM
10/01/10 10:44 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Race only? Remove the side marker light and mount a plate with the switch in it where the lense was.
EDIT: Not sure if this is legal these days, being on the side of the car. My friend did this to his Road Runner back in the early 90's.
Re: Master cut off switch on a duster [Re: Dart1031] #819190
10/01/10 11:03 PM
10/01/10 11:03 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
dont believe that will pass tech I dont have my rule book handy but I seem to recall it states kill switch must be in rear of vehicle.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Master cut off switch on a duster [Re: dusturbd340W5] #819191
10/01/10 11:05 PM
10/01/10 11:05 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
I fixed my post when you quoted me, lol. I'm not sure now either.
Re: Master cut off switch on a duster [Re: dusturbd340W5] #819192
10/01/10 11:08 PM
10/01/10 11:08 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
look at the red knob near the battery
its against the tail ligth
going througth it
1.39 9.85 - 137 mph
Re: Master cut off switch on a duster [Re: Dart1031] #819193
10/01/10 11:09 PM
10/01/10 11:09 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Some tech guys don't like switches or charging posts on the sides in case the car rubs the wall.
Actually, the rear mount for the kill might be an NHRA rule.
Mine has it below the trunk lock cylinder, between the horizontal body line and the bumper.
On my Roadrunner, I ran it through the back-up lamp lens.
Both are rotary switches.
Re: Master cut off switch on a duster [Re: Locomotion] #819194
10/01/10 11:10 PM
10/01/10 11:10 PM
Western,Pa.
MagnumDartSport Offline
Western,Pa.
How about the AWESOME end of your push-pull switch!!
I don't have a pic to post but it is a one-off CNC design.
Anyway,just wanted to give Myron a belated Happy Birthday!!!
Terry n Barb
Re: Master cut off switch on a duster [Re: MagnumDartSport] #819195
10/01/10 11:46 PM
10/01/10 11:46 PM
Locomotion Offline
Locomotion  Offline
Re: Master cut off switch on a duster [Re: Locomotion] #819196
10/02/10 12:07 AM
10/02/10 12:07 AM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
I am not trying to hijack the post, but I am trying to figure out where to put a shutoff on the rear of my 68 Valiant. The trunk lid comes down to the bumper. Any ideas? Any pictures?
Thanks, John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Master cut off switch on a duster [Re: gearhead01] #819197
10/02/10 12:29 AM
10/02/10 12:29 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
in trunk, by tail light
Re: Master cut off switch on a duster [Re: SG duster] #819198
10/02/10 12:36 AM
10/02/10 12:36 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Yeah, it's got a smallblock.
Re: Master cut off switch on a duster [Re: 340B5] #819199
10/02/10 12:58 AM
10/02/10 12:58 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I mounted my flaming river push pull swith to the side of the trunk brace that holds the lock mechanism then ran the rod just to the left of the lock on the outside. Looks great and works great
Re: Master cut off switch on a duster [Re: gearhead01] #819200
10/02/10 01:10 AM
10/02/10 01:10 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Thanks, John
Mine is between the bumper and deck lid, by r/s
tail lite. Its a push switch, rod doesn't get in
the way ...
Re: Master cut off switch on a duster [Re: SG duster] #819201
10/02/10 04:24 AM
10/02/10 04:24 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
my switch is mounted where there would be the trunk key/lock..
I use a continuous duty relay for the alternator shutoff..
Re: Master cut off switch on a duster [Re: B1KILLER] #819202
10/02/10 02:40 PM
10/02/10 02:40 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
B1Killer -Thanks. I like that better than my first idea which was farther to the left. Which would cause me to put an open end slot in my fiberglass trunk lid. Your way, all i have to do is notch or chamfer the corner. Less chance to start a crack.
Thanks again.
John
Re: Master cut off switch on a duster [Re: gearhead01] #819203
10/03/10 12:48 PM
10/03/10 12:48 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I have a pin-on deck lid, so I also used the original trunk key opening to mount my master switch.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Master cut off switch on a duster [Re: nhramark] #819204
10/03/10 08:10 PM
10/03/10 08:10 PM
I like the KISS princple so I mounted mine here. I ran the cables through the rubber drain plug in the spare tire well and used two # 10 self tappers to mount the bracket onto the bottom ledge of the bumper No holes to fill or worry about later BTW, this is the second switch, I burnt the first one up in four years, MR Gasket or Moroso this one is a Summit 250 AMP, it is labeled with the on and off positions, very nice peice. I have had it mounted there since day one and have not had a peep form any of the techs inspectors yet , 10 or 12 different tracks
