1" abody torsion bars .. too stiff ? #818312
09/30/10 09:14 AM
09/30/10 09:14 AM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
Are 1" torsion bars too big for 340 A body street car {with no sway bar} yet ? I would have prefered .92 but the prices are crazy.. found 1" bars for $200 at Just Suspensions .
Re: 1" abody torsion bars .. too stiff ? [Re: RTshaker] #818313
09/30/10 10:55 AM
09/30/10 10:55 AM
Fresno, CA
Jim_Lusk Online content
Jim_Lusk  Online Content
Fresno, CA
I don't think they are too stiff, but my son's Barracuda has 1.14" bars with big sway bars and KYB shocks (known for stiffness) and I think it rides fine..........
Re: 1" abody torsion bars .. too stiff ? [Re: Jim_Lusk] #818314
09/30/10 07:15 PM
09/30/10 07:15 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I run 1.19 inches bars on the street. Not too harsh for me. I run the nose so low that I had to remove the bump stops. NEVER had it bottom out in 12000 miles.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 1" abody torsion bars .. too stiff ? [Re: RTshaker] #818315
09/30/10 10:54 PM
09/30/10 10:54 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
...found 1" bars for $200 at Just Suspensions .
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
Re: 1" abody torsion bars .. too stiff ? [Re: RTshaker] #818316
10/01/10 01:32 AM
10/01/10 01:32 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
what size rims and tires are you running? sidewall height and stiffness are important to know in determining appropriate spring rates.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: 1" abody torsion bars .. too stiff ? [Re: blown340] #818317
10/01/10 02:23 AM
10/01/10 02:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I ran .99"/1" torsion bars from 1994 up until last month. About 60,000 miles on them.
Ran 225/60/15's, 225/50/15's, 245/50/15's, 235/60/15's tires over that period. The shorter sidewalled tires were always a little harsher.
I'd try to run some other shock than a KYB with 1" t-bars. Like a Bilstein. That will give you a better ride. But those are $400 for 4 shocks.
Re: 1" abody torsion bars .. too stiff ? [Re: autoxcuda] #818318
10/01/10 08:45 AM
10/01/10 08:45 AM
RTshaker Offline OP
RTshaker  Offline OP
Tire size is 235/60r-14 on 14x7 Alum.rim .Yes I had read the post on Just suspension ..but for a torsion bar even if made in china a pretty simple device ..maybe they will be alittle soft or under spec just what I need anyway closer to a.92 rate LOL.???
Re: 1" abody torsion bars .. too stiff ? [Re: RTshaker] #818319
10/01/10 09:06 AM
10/01/10 09:06 AM
the house on the left.
cogen80 Offline
cogen80  Offline
they will be firm but not hard and stiff. i think you'll like them.
Re: 1" abody torsion bars .. too stiff ? [Re: cogen80] #818320
10/01/10 09:07 AM
10/01/10 09:07 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I went to 1" bars over a year ago and love em!
