console #818066
09/29/10 10:31 PM
09/29/10 10:31 PM
fredericksburg virginia
mopwrd340 Offline OP
i just picked up a 69 rr for my project . the car came with a center console which i beleive goes to a 66 charger. it is missing the back half of it does somebody make this part or should i sell it and get what i need . also this console has the factory tach thanks ronny
Re: console [Re: mopwrd340] #818067
09/30/10 02:50 AM
09/30/10 02:50 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The 66-67 Charger never had the tach on the console since it was in the dash. Chargers had a clock there (or perhaps the vacuum gauge). Other b-bodies had a piece that attached to the back of the console and used the tach (which is fairly valuable if it works).
Re: console [Re: Jim_Lusk] #818068
09/30/10 03:02 PM
09/30/10 03:02 PM
i seen this console on e bay they said it came off a 66 whatyears would have used this . does anybody know how to wire this tach .
Re: console [Re: mopwrd340] #818069
09/30/10 07:46 PM
09/30/10 07:46 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
If it is a 66 tach it needs a separate sending unit.
Re: console [Re: Jim_Lusk] #818070
09/30/10 09:14 PM
09/30/10 09:14 PM
it has 3 wires so it probaly does
Re: console [Re: mopwrd340] #818071
10/01/10 01:27 AM
10/01/10 01:27 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yep, three wires is a 66 and needs the sending unit, BUT check with http://rt-eng.com/mediawiki/index.php/Main_Page (Real Time Engineering) and see if their replacement tach board will work with the 66 dial. If it will your problem is solved.
Re: console [Re: Jim_Lusk] #818072
10/01/10 03:36 AM
10/01/10 03:36 AM
thanks for the info
Re: console [Re: mopwrd340] #818073
10/01/10 02:04 PM
10/01/10 02:04 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
If you post a picture, it may help in figureing out what its from. Just a thought.
Re: console [Re: mopwrd340] #818074
10/01/10 06:17 PM
10/01/10 06:17 PM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
The back end of some of those older consoles had a cigarette lighter and/or a floor light. When you open the car doors the front console lights and that back light would illuminate the floor areas.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: console [Re: JOES4FORTY] #818075
10/01/10 10:58 PM
10/01/10 10:58 PM
ill try to post pics this weekend its a mopar tach the top plate holes were made for it. isaw one on e bay just like it.ill get the part numbers on the plate to i dont beleive the car came with a console as i see no evidence of bracketry i beleive it was a column shift. car
Re: console [Re: mopwrd340] #818076
10/02/10 09:17 PM
10/02/10 09:17 PM
im having a hard time posting pics . the tach is a 4 wire not a 3 wire
