Oiling mods on 440, front bearing? #817543
09/29/10 04:03 PM
09/29/10 04:03 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
When opening the passages from the main bearings to the oil gally, I noticed that the front main bearing doesn't have this passage. Anything to do there?
Re: Oiling mods on 440, front bearing? [Re: polkat] #817544
09/29/10 04:07 PM
09/29/10 04:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it does, don't have a block in front of me to tell you exactly where though. .
Re: Oiling mods on 440, front bearing? [Re: polkat] #817545
09/29/10 04:29 PM
09/29/10 04:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It runs on an angle right up to the front cam journal.
Re: Oiling mods on 440, front bearing? [Re: buildanother] #817546
09/29/10 04:37 PM
09/29/10 04:37 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...like so.
Re: Oiling mods on 440, front bearing? [Re: thehemikid] #817547
09/29/10 04:50 PM
09/29/10 04:50 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Nice pic. As it shows, the passage splits off from the cam journal passage a little ways up from the main (my arrow in the pic below). This is easily accessable in mains 2 through 5.
BUT...then again, it looks like oil flows away from the main in number 1 instead of to the mains in the others. So maybe no mod is required here?
Re: Oiling mods on 440, front bearing? [Re: polkat] #817548
09/29/10 05:15 PM
09/29/10 05:15 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Pressure, but then again #4 has a problem with getting oil at higher RPM's.
Re: Oiling mods on 440, front bearing? [Re: polkat] #817549
09/29/10 06:29 PM
09/29/10 06:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is just the way the picture is drawn , oil goes in 2 directions from the main galley that goes across the front of the block, the mod is to open passage that flows towards the main and to restrict the passage going to the cam.
Re: Oiling mods on 440, front bearing? [Re: thehemikid] #817550
09/29/10 06:32 PM
09/29/10 06:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is true , there is a mod that can be done that will direct feed the head and you block off the passage from the cam , you have to add a restrictor to each head .
Re: Oiling mods on 440, front bearing? [Re: polkat] #817551
09/29/10 06:43 PM
09/29/10 06:43 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...How much hp & rpm are building for?
Re: Oiling mods on 440, front bearing? [Re: thehemikid] #817552
09/29/10 06:52 PM
09/29/10 06:52 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Not that much, maybe 6000rpm at 400+hp, but I've had bottom end oiling problems on B/RB mild builds before, particularly with oil starved rod bearings. I'd feel better if I could just get a bit more oil down there. I've already drilled the 2 thru 5 passages to the galley to 9/32's from the main saddles but got confused when I got to #1 and thought I'd ask.
Re: Oiling mods on 440, front bearing? [Re: polkat] #817553
09/29/10 07:43 PM
09/29/10 07:43 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...I'm going to ask a silly question now. Have you run a high volume pump & still had oiling problems?
Re: Oiling mods on 440, front bearing? [Re: polkat] #817554
09/29/10 08:54 PM
09/29/10 08:54 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
With all due respect....
If you had problems at that level, it had nothing to do with the block. I have built legions of B/RB's with way more power than that and have had no failures that you refer to. The bottom ends on these engines are particularly good, especially when compared to some of the other offerings from Detroit during the same time period.
MB
Re: Oiling mods on 440, front bearing? [Re: HPMike] #817555
09/29/10 09:14 PM
09/29/10 09:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I think a bottom end oiling mod is not necessary for a street engine.
I ran two separate oil lines from the sending unit to my turbochargers and didn't have ANY oil related issues spinning above 6000 rpm. I ran it like that for more than 10 years.
Run a decent high volume (NOT high pressure) pump and you'll be fine. Be sure your bearing clearances are where they should be.
- Stu Harmon
Re: Oiling mods on 440, front bearing? [Re: polkat] #817556
09/29/10 10:59 PM
09/29/10 10:59 PM
yes there is a prob w the oil velocity blowing past the #4 main & not being able to make the sharp turn & the 2 rods fed from that main losing their bearings from starvation. As you know on SOME builds it's been a prob. Several fixes, one is an oil bypass line in the valley to slow it down. Been away from BB's for a long time so I've lost track of em.(Got a 451 slowly coming together though ). Andyf would have some good info on this. You can drill each vertical crank to cam passage & screw in a setscrew drilled to 1/16" which is plenty of oil for the cam journals/bearings ex for the one that feeds the heads and to elim that one drill horizontally into the rear of each head then up at an angle to the rear pedestal & tap into the NPT plug at the top rear of the block & T off of it to feed both heads that way & restrict each head to ~.080". this will let you restrict all 5 cam bearing oil passages to 1/16" but the #1 concern is the #4 main which MAY not be a prob w your rpm but you're into it and it's at the point where this is the time to research/add it. Definitely finish checking/drilling the 5 gallery to crank angled passages.
Re: Oiling mods on 440, front bearing? [Re: RapidRobert] #817557
09/30/10 02:02 AM
09/30/10 02:02 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
RapidRobert said, "Definitely finish checking/drilling the 5 gallery to crank angled passages."
Which brings me back to my original question; I can't see the angled passage through the #1 main bearing hole, which immediately slants down at an angle toward the front of the block (with the block upside down). I've drilled the rest, but how do I drill that one?
Re: Oiling mods on 440, front bearing? [Re: polkat] #817558
09/30/10 08:01 AM
09/30/10 08:01 AM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
The oil passage that goes between the #1 main brg and #1 cam brg intersects the passage that goes from the oil pump to the main oil galley. The intersection is about half way between the main brg and cam brg. You would probably only have to drill from the main brg up to the point where they intersect. I would think that the #1 main would have plenty of pressure as it is. Plus that passage only feeds one rod brg, not two like #'s 2,3,and 4.
Re: Oiling mods on 440, front bearing? [Re: HPMike] #817559
09/30/10 08:13 AM
09/30/10 08:13 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
... but I've had bottom end oiling problems on B/RB mild builds before, particularly with oil starved rod bearings.
You also used fully grooved mainbearings with a HV-oilpump back then?
Re: Oiling mods on 440, front bearing? [Re: RapidRobert] #817560
09/30/10 09:47 AM
09/30/10 09:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I did that to my first 383 build but drilled an 1/8" hole , now I just drill a new smaller hole in the cam bearing and install it with the new hole over the passage .
