Re: Oiling mods on 440, front bearing?
[Re: polkat]
#817549
09/29/10 06:29 PM
09/29/10 06:29 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Nice pic. As it shows, the passage splits off from the cam journal passage a little ways up from the main (my arrow in the pic below). This is easily accessable in mains 2 through 5. BUT...then again, it looks like oil flows away from the main in number 1 instead of to the mains in the others. So maybe no mod is required here?
That is just the way the picture is drawn , oil goes in 2 directions from the main galley that goes across the front of the block, the mod is to open passage that flows towards the main and to restrict the passage going to the cam.
[Re: thehemikid]
#817550
09/29/10 06:32 PM
09/29/10 06:32 PM
JohnRR
U.S.S.A.
...Pressure, but then again #4 has a problem with getting oil at higher RPM's.
That is true , there is a mod that can be done that will direct feed the head and you block off the passage from the cam , you have to add a restrictor to each head .
[Re: polkat]
#817551
09/29/10 06:43 PM
09/29/10 06:43 PM
Posts: 1,805 ky hills
thehemikid
ky hills
When opening the passages from the main bearings to the oil gally, I noticed that the front main bearing doesn't have this passage. Anything to do there?
...How much hp & rpm are building for?
[Re: polkat]
#817554
09/29/10 08:54 PM
09/29/10 08:54 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Not that much, maybe 6000rpm at 400+hp, but I've had bottom end oiling problems on B/RB mild builds before, particularly with oil starved rod bearings. I'd feel better if I could just get a bit more oil down there. I've already drilled the 2 thru 5 passages to the galley to 9/32's from the main saddles but got confused when I got to #1 and thought I'd ask.
With all due respect....
If you had problems at that level, it had nothing to do with the block. I have built legions of B/RB's with way more power than that and have had no failures that you refer to. The bottom ends on these engines are particularly good, especially when compared to some of the other offerings from Detroit during the same time period.
MB
[Re: HPMike]
#817555
09/29/10 09:14 PM
09/29/10 09:14 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I think a bottom end oiling mod is not necessary for a street engine. I ran two separate oil lines from the sending unit to my turbochargers and didn't have ANY oil related issues spinning above 6000 rpm. I ran it like that for more than 10 years. Run a decent high volume (NOT high pressure) pump and you'll be fine. Be sure your bearing clearances are where they should be.
[Re: HPMike]
#817559
09/30/10 08:13 AM
09/30/10 08:13 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
... but I've had bottom end oiling problems on B/RB mild builds before, particularly with oil starved rod bearings.
You also used fully grooved mainbearings with a HV-oilpump back then?
[Re: RapidRobert]
#817560
09/30/10 09:47 AM
09/30/10 09:47 AM
JohnRR
U.S.S.A.
You can drill each vertical crank to cam passage & screw in a setscrew drilled to 1/16" which is plenty of oil for the cam journals/bearings
I did that to my first 383 build but drilled an 1/8" hole , now I just drill a new smaller hole in the cam bearing and install it with the new hole over the passage .
