fasteners with sealer #817471
09/29/10 03:25 PM
09/29/10 03:25 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Specifically the nuts that hold the 72-74 Challenger tail light housings to the tail panel but applies to any fastener that had sealer on it.
I refinished the nuts but they had sealer on them from the factory. What should I use to put back on them? I thought about buying some strip calk and filling them with that. The origonal sealer seamed to be that consistancy.
Re: fasteners with sealer [Re: burdar] #817472
09/29/10 03:32 PM
09/29/10 03:32 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used UltraSeal black gasket compound. It looks and feels like the old stuff, remaining kinda gooey after it dries. It's hard to tell the difference.
Re: fasteners with sealer [Re: burdar] #817473
09/29/10 03:41 PM
09/29/10 03:41 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Darren, are you sure yours came with nuts and sealer? My 73 came with the white plastic "tubes" that you pushed into the hole first, then the studs on the letters pushed into the "tubes".
Re: fasteners with sealer [Re: 318 Stroker] #817474
09/29/10 03:58 PM
09/29/10 03:58 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I'm not talking about the letters. I'm talking about the tail light housing nuts. There are six nuts per side and have sealer in them.
Where did you get the gasket compound?
Were the plastic tubes on your car white? I see them listed online and they are pink. To be honest, I don't remember removing the letters and have no idea what was there origonally.
Re: fasteners with sealer [Re: burdar] #817475
09/29/10 04:35 PM
09/29/10 04:35 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Sorry, I read your post to quickly. As for the letters, the "tubes" were shot, so I used the repro letters with the nuts. I don't remember what I used on the taillights.
Re: fasteners with sealer [Re: 318 Stroker] #817476
09/29/10 05:04 PM
09/29/10 05:04 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I googled "UltraSeal black gasket compound" and the only thing that came up was black silicon by Permatex. That can't be right.
Re: fasteners with sealer [Re: burdar] #817477
09/29/10 05:55 PM
09/29/10 05:55 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yup, believe it or not. It's pretty close. most auto parts stores have it. If you don't like it, you can always use it elsewhere for gaskets. it's great stuff!
http://www.amazon.com/Permatex-82180-Max...bxgy_auto_img_b
Re: fasteners with sealer [Re: jbc426] #817478
10/01/10 06:08 PM
10/01/10 06:08 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
You can get black butyl strip caulk from any body parts store. Or I just found a nice black caulk thats not gooey like the butyl thats used on many of the Ford and AMC heater boxes to seal the blower resistors and blower motors. I get it right from the manufacturer that only sells wholesale. Think Norton has a version of black caulk. Think one of those would be very correct.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: fasteners with sealer [Re: 71TA] #817479
10/01/10 06:12 PM
10/01/10 06:12 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Again pretty sure Norton makes a black version of this. More like a rope caulk that you use to seal drafty windows than the gooey butyl type caulk like the stuff used to attach your windshield.
Re: fasteners with sealer [Re: 71TA] #817480
10/02/10 11:29 AM
10/02/10 11:29 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I'm at the shop this AM bagging some of this stuff. Shoot me your address Darren and I'll send you a dozen strips of each.
Re: fasteners with sealer [Re: 71TA] #817481
10/02/10 04:57 PM
10/02/10 04:57 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
PM sent. Thanks James!
