1965 318 dodge changed to a 383/440 #817038
09/28/10 10:42 PM
09/28/10 10:42 PM
Illinois
Craig61 Offline OP
Craig61  Offline OP
Illinois
Ok if its a dumb question I'm sorry,but its been a long time since , I built a mopar car. The question is several folds. The car has a 318 auto in it. If I change it to a 383 or 440 are the brackets alternater water pumps starter and so on from the 318 useable on the 383/440? Last dumb question is. Can the auto trans from the 65 dodge Cornet 318 be used on the 383/440 ?
Re: 1965 318 dodge changed to a 383/440 [Re: Craig61] #817039
09/28/10 11:00 PM
09/28/10 11:00 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
You have to change all brackets.Transmission has to be changed also.Alternator,starter will fit.Water pump different.
Re: 1965 318 dodge changed to a 383/440 [Re: gtx69] #817040
09/29/10 02:41 AM
09/29/10 02:41 AM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Engine mount brackets are different too, but the K member will work.
Re: 1965 318 dodge changed to a 383/440 [Re: Craig61] #817041
09/29/10 12:49 PM
09/29/10 12:49 PM
KY
rbds65 Offline
rbds65  Offline
KY
If it has power steering, the pump bracket is different, only year for that bracket I think. The pump is the same. You will want to change torsion bars also. rbd
Re: 1965 318 dodge changed to a 383/440 [Re: rbds65] #817042
09/29/10 06:32 PM
09/29/10 06:32 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Engine mounts should be the same in 65.I have a SB set in the garage.They are identical to the ones on my 440.Rocky
Chrysler Firepower
Re: 1965 318 dodge changed to a 383/440 [Re: therocks] #817043
09/30/10 09:38 PM
09/30/10 09:38 PM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
steel engine mounts are not the same small block to big block in 63-65. I believe one of them is close but the other side is WAAAAAAAY different ... the rubber mounts are the same
Re: 1965 318 dodge changed to a 383/440 [Re: 68_CONV_300] #817044
09/30/10 11:17 PM
09/30/10 11:17 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
B-body 1963-1964-1965 B-bodies use the same rubber motor mount insulators,regardless of engine....273-318-361-383-413-426W also use the same V8 k-frame....all you need to go big block is a set of the proper steel engine mounting brackets that fit big block, pictured here. exact duplicates of factory mounts....made in Wisconsin.
Re: 1965 318 dodge changed to a 383/440 [Re: Craig61] #817045
10/03/10 08:39 AM
10/03/10 08:39 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Joe is right. The engine brackets are different as is almost everything else. If you really want to change from the old reliable poly 318, you may want to consider a later model LA engine. Less weight, less work, fewer dollars, same trans.
This is the land of the free because of the brave
Re: 1965 318 dodge changed to a 383/440 [Re: Joesixpack] #817046
12/20/11 03:19 PM
12/20/11 03:19 PM
North Carolina
coololdcars Offline
coololdcars  Offline
North Carolina
I need big block brackets for my 1965 Coronet!!!! skully28016@yahoo.com. Belmont , NC
Re: 1965 318 dodge changed to a 383/440 [Re: coololdcars] #817047
12/20/11 11:42 PM
12/20/11 11:42 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
look in 1970 and back B-body parts for sale, or big block engine parts for sale, i have been selling them for about 10 years on this site.
