What 727 FRONT PUMP with a trans brake #816954
09/28/10 08:56 PM
09/28/10 08:56 PM
TN
SCATPACK 1 Offline OP
TN
75 MODEL TRANS BEHIND A 572. Running a trans brake and it is a 75 model if it makes any difference. Is there preferred front pump to have when using a trans brake.
Just making sure I get the right one while I have the trans out for freshening.
THANKS
Old Geezer Racing
Re: What 727 FRONT PUMP with a trans brake [Re: SCATPACK 1] #816955
09/29/10 12:13 AM
09/29/10 12:13 AM
TN
TN
Anybody use a 727 any more???
Old Geezer Racing
Re: What 727 FRONT PUMP with a trans brake [Re: SCATPACK 1] #816956
09/29/10 01:42 AM
09/29/10 01:42 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
just make sure your stock pump is in good shape clearance and spec wise, and better pump gears would be a plus, if for nothing other than peace of mind, I just broke the drive tang's off the gear in my 904 and I will be spending good money to make sure that don't happen again.
Re: What 727 FRONT PUMP with a trans brake [Re: dartman366] #816957
09/29/10 09:56 AM
09/29/10 09:56 AM
TN
TN
You earlier post is what got me to thinking about upgrading the front pump.
So is there any actual difference in front pumps and in the pump gears? Is there any difference internally in any of the pumps available? What should I be looking for in the pump or gears?
Thanks again for your knowledge and help
Old Geezer Racing
Re: What 727 FRONT PUMP with a trans brake [Re: SCATPACK 1] #816958
09/29/10 10:09 AM
09/29/10 10:09 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I don't believe there is any difference in pumps with in year groups, I know there are some differences in internal oiling that prevent the interchange of certain parts, (mabey one of the guru's will verify this),,as far as the pump gears some have gotten away with stock replacement part's and some have had to go to the high dollar billet piece's, I am going with the billet parts cause I want to eliminate a weak link that cost me a weekend of racing.
Re: What 727 FRONT PUMP with a trans brake [Re: dartman366] #816959
09/29/10 02:20 PM
09/29/10 02:20 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
727 pump covers are the same. Early and late have differnt style vents , but thats it. Its the pump stators that are differnt.
62-66 uses a 19 spline input shaft and a narrow bushing on the front drum.
67-70 uses a 24 spline input shaft and a narrow bushing on the front drum. Both the 62-66 & the 67-70 you can not use a aftermarket billet front drum. As all billet drums use a wide bushing.
71-77 and 78 & up non lock up, uses a 24 spline input shaft and a wide bushing on the front drum, and can be used with billet front drums.
71-77 uses a 2 ring input shaft
78&up uses a 2 ring input shaft and 1 ring on the rear drum.
Re: What 727 FRONT PUMP with a trans brake [Re: SCATPACK 1] #816960
09/29/10 03:12 PM
09/29/10 03:12 PM
NC
440Jim Offline
440Jim  Offline
NC
Use a pump/stator support with the pressure passage to the front drum ported between the ring grooves. Many transbrake valve bodies have this in their instructions.
http://www.tciauto.com/Instructions/ResultsContent.aspx?query=121900
Step 4, illustration 3.
CRT sells modified pumps like this.
Modified Pump Supports enlarged 3rd gear oil feed. Machined on the gear side for trueness. 727PS-5 727 1971-78
And at least put new pump gears in to reduce the chance of fatigue cracking on the pump lugs. Or buy the HD ones.
Re: What 727 FRONT PUMP with a trans brake [Re: SCATPACK 1] #816961
09/29/10 04:00 PM
09/29/10 04:00 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
As part of an "Increased cooling package" the front pump was changed in '74, the most noticeable change is a reduction in the size of the cast counterbores in the pump housing and the reaction shaft support; this provides more seal off area for the face of the inner rotor.
At the same time the front clutch lube orifice in the reaction shaft support was eliminated, so a '74 and later pump has some good features and some bad (IMO).
I always drill the lube orifice when building a '74 or later 727, this requires an extension drill.
Also, it's important to keep the '74 and later input shaft with the like-year reaction shaft support as there are differences in the bushing lube ports.
Re: What 727 FRONT PUMP with a trans brake [Re: John_Kunkel] #816962
09/29/10 04:04 PM
09/29/10 04:04 PM
Rio Linda, CA
Rio Linda, CA
Counterbore differences
Re: What 727 FRONT PUMP with a trans brake [Re: John_Kunkel] #816963
07/12/12 01:28 AM
07/12/12 01:28 AM
California
DamienH Offline
DamienH  Offline
California
I know this topic is a little old but I have a question John. I didn't know about the max cooling stator support change in 1974. I used an early front pump with the metal vent baffle but I'm not sure if I used a stator support with the max cooling changes or without the max cooling changes. I do know I used a wide bushings stator support. Is there a problem with using an early front pump with a max cooling stator support and vice versa.
Thank You
Re: What 727 FRONT PUMP with a trans brake [Re: DamienH] #816964
07/12/12 02:46 PM
07/12/12 02:46 PM
Rio Linda, CA
Rio Linda, CA
It's not a good idea to mix parts, the combination of some supports and input shafts will eliminate lube in some areas.
Re: What 727 FRONT PUMP with a trans brake [Re: John_Kunkel] #2867142
12/31/20 08:11 PM
12/31/20 08:11 PM
So cal
E
EFI DART Offline
EFI DART  Offline
E
So cal
Hey all,
Can any of you guys please provide the matching photos on the input shafts , Stators and oil pumps ( WIde Bushing related only )\
Moparaaaaaaars
