What 727 FRONT PUMP with a trans brake
#816954
09/28/10 08:56 PM
09/28/10 08:56 PM
Posts: 1,505 TN
SCATPACK 1
TN
75 MODEL TRANS BEHIND A 572. Running a trans brake and it is a 75 model if it makes any difference. Is there preferred front pump to have when using a trans brake. Just making sure I get the right one while I have the trans out for freshening. THANKS
Old Geezer Racing
Re: What 727 FRONT PUMP with a trans brake
[Re: SCATPACK 1]
#816956
09/29/10 01:42 AM
09/29/10 01:42 AM
dartman366
Mt. Vernon, Ohio
just make sure your stock pump is in good shape clearance and spec wise, and better pump gears would be a plus, if for nothing other than peace of mind, I just broke the drive tang's off the gear in my 904 and I will be spending good money to make sure that don't happen again.
[Re: SCATPACK 1]
#816958
09/29/10 10:09 AM
09/29/10 10:09 AM
dartman366
Mt. Vernon, Ohio
You earlier post is what got me to thinking about upgrading the front pump. So is there any actual difference in front pumps and in the pump gears? Is there any difference internally in any of the pumps available? What should I be looking for in the pump or gears? Thanks again for your knowledge and help
I don't believe there is any difference in pumps with in year groups, I know there are some differences in internal oiling that prevent the interchange of certain parts, (mabey one of the guru's will verify this),,as far as the pump gears some have gotten away with stock replacement part's and some have had to go to the high dollar billet piece's, I am going with the billet parts cause I want to eliminate a weak link that cost me a weekend of racing.
[Re: SCATPACK 1]
#816960
09/29/10 03:12 PM
09/29/10 03:12 PM
Posts: 16,928 NC
440Jim
NC
Use a pump/stator support with the pressure passage to the front drum ported between the ring grooves. Many transbrake valve bodies have this in their instructions. http://www.tciauto.com/Instructions/ResultsContent.aspx?query=121900Step 4, illustration 3. CRT sells modified pumps like this. Modified Pump Supports enlarged 3rd gear oil feed. Machined on the gear side for trueness. 727PS-5 727 1971-78 And at least put new pump gears in to reduce the chance of fatigue cracking on the pump lugs. Or buy the HD ones.
[Re: DamienH]
#816964
07/12/12 02:46 PM
07/12/12 02:46 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's not a good idea to mix parts, the combination of some supports and input shafts will eliminate lube in some areas.
[Re: John_Kunkel]
#2867142
12/31/20 08:11 PM
12/31/20 08:11 PM
Posts: 11 So cal
EFI DART
So cal
Hey all, Can any of you guys please provide the matching photos on the input shafts , Stators and oil pumps ( WIde Bushing related only )\
Moparaaaaaaars
