amd hoods #816321
09/27/10 10:04 PM
09/27/10 10:04 PM
wellington ohio
68-scatpack-rt Offline OP
In thin ice
In thin ice
wellington ohio
anyone have any experience on the quality of the replacement hoods from amd? (1969 roadrunner to be specific)
how's the fitment? is the metal as thick as the og ones?
thanks.
unions....the folks who brought you the weekend!
Re: amd hoods [Re: 68-scatpack-rt] #816322
09/27/10 10:48 PM
09/27/10 10:48 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
i have one on my 69 rr. the fit and alignment is right on the mark. i am not sure on metal thickness. i think it might weigh just a little less than my original but it seems fine to me.
Re: amd hoods [Re: 68-scatpack-rt] #816323
09/27/10 10:52 PM
09/27/10 10:52 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've only had the Shaker E bodie and 69 Charger hoods,...but they were all excellent in regards to fit and finish, the sheetmetal is thicker approx .040 were as the factory hoods are .030,...I've heard from those that have bought the 69 RR hood that is was also a nice peice, and the factory vents/side scoops also fit with no issuse
Mike
Re: amd hoods [Re: DAYCLONA] #816324
09/27/10 11:14 PM
09/27/10 11:14 PM
Shelby, Ohio
2
Shelby, Ohio
i'm thinking now that the reason my AMD hood weighs less than my original is the new hood has e-coat only while my original is painted and also has some filler in it from previous repairs. and as Dayclona stated, my vents fit perfect.
Re: amd hoods [Re: 68-scatpack-rt] #816325
09/27/10 11:58 PM
09/27/10 11:58 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I have an AMD R/T hood on my 72 Challenger nice piece.
Re: amd hoods [Re: 68-scatpack-rt] #816326
09/28/10 12:41 AM
09/28/10 12:41 AM
Jacksonville Florida
elitecustombody Offline
I find it hard to believe that AMD hoods weigh less than stock, unless as noted it has tons of bondo and paint.I've sold plenty of of AMD hoods and not person has mentioned any issues, I just installed AMD 400 hood on my 69 Firebird and it fits and latches better than the OEM flat hood,which was perfect,no previous bodywork of any kind
Re: amd hoods [Re: 68-scatpack-rt] #816327
09/28/10 12:51 AM
09/28/10 12:51 AM
NY usa
540challenger Offline
NY usa
If anything i would think the AMD hood would weigh a little more only b/c they use a thicker gauge sheet metal then the OE
Re: amd hoods [Re: elitecustombody] #816328
09/28/10 06:39 AM
09/28/10 06:39 AM
wellington ohio
In thin ice
In thin ice
wellington ohio
thanks guys! that's what i needed to know.
Re: amd hoods [Re: 68-scatpack-rt] #816329
09/28/10 08:48 AM
09/28/10 08:48 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I've been told the mounting holes where the rivets attach the center box for the air grabber are larger in OD than the original hood, thus causes attaching issues if you plan to run the factory air grabber box
