6 pack vacuum line
#816016
09/27/10 05:34 PM
09/27/10 05:34 PM
Posts: 1,505 TN
SCATPACK 1
TN
Does anyone have a diagram or a clear picture that shows where the vacuum line for the secondaries connects to on the center carb? I found a picture in text archives, but it looks like both the distributor and carb vacuum lines are attached to the same outlet port. Thanks
Old Geezer Racing
Re: 6 pack vacuum line
[Re: Mr.Yuck]
#816018
09/27/10 07:01 PM
09/27/10 07:01 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
The port is the lower of the two on the center carb that hooks to the T then the outbord vacuum pods from there. The upper one only has vacuum at part throttle for the vac advance.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
[Re: ProStDodge]
#816020
09/27/10 10:47 PM
09/27/10 10:47 PM
Posts: 1,505 TN
SCATPACK 1
TN
Thanks guys It looks like my metering block has been swapped out at some time by some idiot. Mine only has one place for a vacuum port. How much vacuum should be on the correct port at idle? OR is there a part number for the correct metering block that has the 2 ports on it? Is it Ok to run the vacuum line to the base plate if the port on the metering block will not work right?
Old Geezer Racing
