6 pack vacuum line #816016
09/27/10 05:34 PM
09/27/10 05:34 PM
TN
SCATPACK 1 Offline OP
TN
Does anyone have a diagram or a clear picture that shows where the vacuum line for the secondaries connects to on the center carb? I found a picture in text archives, but it looks like both the distributor and carb vacuum lines are attached to the same outlet port.
Old Geezer Racing
Re: 6 pack vacuum line [Re: SCATPACK 1] #816017
09/27/10 06:52 PM
09/27/10 06:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ok I have a 6-pack and should know this... I think the outboards hook into the port on the main carb. The vac advance should run of manifold vacuum? I don't run that so I don't know. As I recall..and if nobody chimes in, I'll go look at mine, the "T" comes of the center carb.
Coming soon!!!!
Re: 6 pack vacuum line [Re: Mr.Yuck] #816018
09/27/10 07:01 PM
09/27/10 07:01 PM
northeast texas
strokin73cuda Offline
northeast texas
The port is the lower of the two on the center carb that hooks to the T then the outbord vacuum pods from there. The upper one only has vacuum at part throttle for the vac advance.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: 6 pack vacuum line [Re: strokin73cuda] #816019
09/27/10 07:16 PM
09/27/10 07:16 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
like this
Pods to lower port on center metering block.
Distributor vacuum advance to top port on center metering block.
Choke pull-off to port on front of center carb base.
Re: 6 pack vacuum line [Re: ProStDodge] #816020
09/27/10 10:47 PM
09/27/10 10:47 PM
TN
TN
Thanks guys
It looks like my metering block has been swapped out at some time by some idiot. Mine only has one place for a vacuum port. How much vacuum should be on the correct port at idle? OR is there a part number for the correct metering block that has the 2 ports on it? Is it Ok to run the vacuum line to the base plate if the port on the metering block will not work right?
Old Geezer Racing
Re: 6 pack vacuum line [Re: SCATPACK 1] #816021
09/27/10 11:02 PM
09/27/10 11:02 PM
Thanks guys
H-- NO, Unless you want wide open throttle at start up Call Chicago Corvette and give them the list number(It is on the back side on the passenger side of the center carb. )and buy the correct metering block for your carb DO NOT hook the outboard carb vacume pod lines to the manifold vacume, if you do it will open the outboard carbs up immediately(SP?) as soon as you start it up Chicago Corvette bought all of the Holley six pak replacements parts years ago, I hope they can help you still . BTW, use the word Tri Power when asking for parts, not Six Pak This will help you stay under there radar as a rich, well heeled Mopar guy
Re: 6 pack vacuum line [Re: Cab_Burge] #816022
09/27/10 11:09 PM
09/27/10 11:09 PM
northeast texas
northeast texas
No Don't do that as Cab said full throotle while engine running on the out-boards also your doing good asking on here these guys are good just don't get in a hurry and do something you regret also try to find someone in your area with six pack experience to help you out. Even if its just with some phone calls.
