Re: Superbird actuator questions
[Re: MONC]
#815601
09/27/10 01:16 PM
09/27/10 01:16 PM
Posts: 10,030 Wisconsin
Aero426
Wisconsin
'70 Charger is electric. BE & A have repopped the actuators, but I "think" the are the '68 actuators. Wilson products can rebuild the original actuators. www.n96airgrabber.com
[Re: MONC]
#815603
09/27/10 01:28 PM
09/27/10 01:28 PM
Posts: 18,157 Mass
DAYCLONA
Mass
You'll need the 69 vacumm canisters, the 68 have a rather large magnet in them,...the 70 Charger is an electric motor,...different animal,... you don't need to remove the nose,..just remove the headlite bulbs and cups and perform surgery thru those holes, 2 nuts that hold the vacumm pod to the adapter bracket,...it'll be tight, real tight!,..cotter pin holding the pods arm to the pivot frame arm, and 1 vacumm line inside the bucket,...get those undone, then insert the replacement pod down thru the latchtray and fender opening,...I hope you have long arms/fingers ,...I've done a few this way on Tona's/Birds
[Re: MONC]
#815605
09/27/10 02:47 PM
09/27/10 02:47 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Thanks for the feedback.
Sounds pretty painful removing them through the nose, but something tells me it's worse taking off the nose to get to them...
Not if you have eight hands.
[Re: Aero426]
#815606
09/27/10 03:17 PM
09/27/10 03:17 PM
Posts: 3,674 The Historic Hudson Valley
MONC
Yeah, their website shows 68 actuators only.
Wilson's rebuilds A/G actuators, not sure if they do headlight ones, they don't mention it...
