restarting engine #81512
06/29/08 09:55 AM
06/29/08 09:55 AM
Maryland
O
otrAlive Offline OP
otrAlive  Offline OP
O
Maryland
71' 340 Duster. I've been working on a restoration of my car for about 7 months and soon I'll be ready to crank it up. Is there anything I should do to the engine prior to starting it? i. e. manually turning it over, oil in the cylinders, etc?.
thanks
Re: restarting engine [Re: otrAlive] #81513
06/29/08 10:18 AM
06/29/08 10:18 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
If you want to got thru the process of priming the oil system, would be better.
I would think at the least, pull the plugs and spin it over til you get Oil Pressure.
Other than that, just fire it up.
Re: restarting engine [Re: cyphre666] #81514
06/29/08 11:29 AM
06/29/08 11:29 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it has been run - make sure that it has a good charged battery and start it. Hell look at all the seasonal engines that are put up in the fall and not started again till summer. No big deal.
Re: restarting engine [Re: MoparforLife] #81515
06/29/08 11:31 AM
06/29/08 11:31 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i would at best pull the plugs and spin the motor..
Tony
70 AARCuda Vitamin C
Re: restarting engine [Re: otrAlive] #81516
06/29/08 12:16 PM
06/29/08 12:16 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If the engine has been rebuilt. Yes, prime it before starting.
